Archive
There is a problem in my PC which is partly my fault but I hope someone can guide me on how to correct it.
The problem is that my PC won’t boot because I installed a RAM chip while the PC was booting up. It turns on but wont boot I tried to make sure everything was fine and restore it but my CD drive won’t work either which means I can’t use the factory restore disk.
Does this mean I destroyed my motherboard or something or is there a problem with the RAM? Any help would be deeply appreciated
Read more
I am experiencing quite a difficult time, trying to upload or update applications with my iPhone. I first thought it was a virus invasion, which proved not to be the case, after I counter scanned the phone with a valid up to date Antivirus and found 0 viruses.
The error message ERROR -- "Application failed code sign verification. The signature was invalid, or it was not signed with an Apple submission certificate."
The first time I got the error message, I was using an original Apple Certificate. I then followed a friend’s suggestion of revoking the original certificate and distribution files....
Read more
I had setup a BIOS password to my computer a few days ago and I had gone for a tour. Unfortunately I did not kept the password safely, I thought i can remember it anytime. But I was wrong. When I come from the tour now I can not remember the password I set in the BIOS. My Motherboard is Intel DG41RQ series. Please tell me what to do?
I really need assistance as I can not able to open My PC. I have many work in my hand but I can not able to do those because some important...
Read more
I am Mahekrajput.
I have a laptop & I have been using it for the past 4 years. My laptop's brand is APPLE model.
A problem has been detected from 2 months. When I am working, it restarts automatically without any message.
Some times my keyboard doesn't work properly. I don't understand what can I do now?
I tried to solve this problem, but I couldn't. Why does my computer restart without any message & my keyboard doesn't work properly?
Please give me a solution about this problem as soon as possible.
mahekrajput
Read more
I have a new Core i7 Desktop PC previously installed on Windows XP. When I try to install Windows 7 on my computer, I receive the Error Code: 0X80070006
I tried many times to fix it, but no result. This happens only when Windows starts to expand the files and at 0%. There are two HD drives and I removed the external one to check what the problem is. In the primary disk there is Windows XP SP3 installed on the C drive. I tried installing Win 7 using a flash drive but same problem. I'm not sure what is...
Read more
I have bought a new computer where it was shipped with Windows 7 and I am not so comfortable with that. So I am looking for shifting to Windows XP before I dump my huge files onto my computer, where doing it in the later point may make it more tough, where I need to take back ups.
So please guide me to install Windows XP. I can even Google it but I just wanted to rely on expert comments, to make sure my brand new computer stays safe.
Read more
In many recent time's antivirus I have observed a protection system called real-time scanning system.
I have used Norton 360, Norton internet security 2009, Norton Antivirus 2008, Eset NOD 32 4.2 and Eset Smart security 4 in all those antivirus software I have seen that this real time scanning system is available.
My first question is that what is the main function of this Real-time file scanning system?
What is the main difference between the normal scanning system and the real-time scanning system?
How it protects our computer?
Why the name real-time scanning is used to define this part of the software?
What is the...
Read more
I recently had some spyware installed on my computer which I removed using the Malwarebytes, however after this it had been removed and I lost connection to the internet.
I am connected to the wireless signal fine with no problem but there is only local access. I have checked the firewall settings and they are ok and the internet is working fine on other computers.
I am running Windows Vista operating system in my PC. I have run Malware bytes again in safe mode and there were two files  still found. I have removed these a couple of times...
Read more
I am using a PC which has Windows 7 Ultimate as operating system.
For security I have to use a user password for my profile as its an official PC the password is really important.
As I am new to my work, sometimes I find it hard to remember my password.
I am worried about it that I may forget the password any time.
So please some one tell me what should I do if I forget the password?
Is there anyway to remove it or recover the password?
If there is anyway please tell me about it and I will be glad...
Read more
While I was surfing the net, I accidentally opened a site that contains malware. My anti virus is outdated,since it came as a pre installed program  when I bought my laptop.
I did not buy a legal and premium anti virus since I don't usually use my computer. And I only use this to communicate with my family and friends outside the country.
While searching on Google, I opened a site that has malicious content. Without knowing that I been hit by a malware virus. My system suddenly slows down, and display repeated error message.
I cannot even shut it down or...
Read more
