Archive
Hi All,
I have been attempting to install the application Printshop 22 on my windows machine and I fail to do so because the Amyuni Document Converter driver installation error. I ensured that my system has .NET 1.1 Framework installed on my windows 7, 32 bit machine as this is known to cause many installation issues. But when I run the installation program, I get the following error message concerning Amyuni Document Converter. As I had no idea on what this particular driver was, I tried updating all the software installed on my machine. I hoped this would update the...
Read more
Hi All,
I get this error whenever I attempt installing the Premium Design Collection instructing me to install Serif Page plus 11 prior to installing Serif Premium Design Collection. I had Serif Page Plus 10 installed on my computer and I tried an upgrade on it to Page Plus 11. Later I tried installing the Premium Design Collection again, only to see this error popping up a second time. I decide to do away with the Page Plus completely and uninstalled it and then tried installing a fresh copy of Page Plus 11.On successful completion of this operation, I rebooted...
Read more
Hi Friends,
I am not able to connect with internet in my laptop. I have windows 7 64 bit Operating system, installation and setup went well. But why I am getting this error. Thinking of any drivers issue so checked and re-install all drivers. And also I tries the common method of restarting, but no luck. Please help me.
Thanks in advance.
Error message:
Connectify: (CF001006) Error Configuring Hotspot
Windows has encountered an error initializing hosted network.
Please check online for suggestions:
https://support.connectify.me/entries/20868143-hostednetwork-errors
Read more
Hi Pals,
I am wondering if anyone of you experienced an issue similar to the one I am about to explain. I am absolutely clueless as to what might me causing this issue. A few days back, I downloaded and installed the Nikon Capture NX2 version 2.2.0 on my Mac machine running OS X 10.8.4. I am using it in the 32 bit mode. This application just quits unexpectedly in the middle of something. I cannot pinpoint when this disappears, it gives an error message out of the blue and simply quits. The error message dialog gives me an option...
Read more
Hi Everyone,
I have been using MeGUI for a few months now. I initially used it with windows vista and recently upgraded to windows 7, 64 bit and am using MeGui 64 bit. Now I seem to encounter a few problems with it. I could perform the following tasks with vista but all these fail to execute well windows 7. Here is a list of what I tried on Vista:
1. Opening an mkv-container with only one vc-1 video stream in it.
2. Tried opening the mkv-file in MPC_x64 and it plays without any issues.
3. Able to create and render a graph...
Read more
Hello All,
I have been trying to install Zone Alarm on my computer for the last 3 days and till now didn’t get any closer to doing it. Windows always reports a compatibility issue and I am blocked from proceeding further. I have windows 8.1 installed on my pc. I tried using the Revo uninstaller to remove Zone Alarm and manually checked to ensure that there are no remnants of Zone Alarm partial install. Further I unistalled Avast and deleted all files pertaining to it just to make sure that the trouble was not from this end. Next I emptied...
Read more
Hello All,
I was attempting to run the VIPRE antivirus 2013 after installing it and I get the following error message stating that the service is not running. I checked the Services running and I find that the "Vipre Antivirus" service is already started. It doesn’t give me a problem when trying to start it or stop it. But the error appears when double clicking the Desktop icon and the tray icon never appears. I am using windows 7 Home premium on my pc. I tried running various other antivirus applications to ensure that there are no possible threats and...
Read more
I had an issue with my Internet Explorer. It won't run and it always shows an error about proxy server. The last time I run my browser, there is no issue found and I can very well use it without problems. Today, when trying to open it, the error states, "The proxy server isn't responding. Check your proxy settings". What is the cause of this issue? Do I need to reinstall or remove my browser and switch to Chrome or Firefox? Please help me.
Read more
I got an error when starting the Operations Manager or even the Service Manager Console. The error says:
Operations Manager
Failed to connect to server 'scom.lab.rickygao.com'
The Data Access service is either not running or not yet initialized. Check the event log...
I'm not sure why this error came up. My SQL Server is up and running and I don't understand why it is failing. Kindly please help me.
Read more
Hi Friends,
I bought Final Cut Express HD 3.5 a few years ago and had been using it on my Mac Book Pro quite comfortably. Now I tried installing this application on my iMac running 10.6.8 and the installation completed without any issues. However, I cannot launch Final Cut on this machine. Every time I attempt this, Final Cut prepares to open but fails to complete the process and I get the error message shown in the below attachment. This error seems to occur while loading the audio filters. I guess the plugin mentioned in the error message is a...
Read more
