Archive
Hello Pro Experts,
The download and installation went pretty well and good without any problem in the computer. However, the problem triggered when I try to perform some actions with Microsoft office document. The error states that this document contains custom code that cannot be loaded. Please guide me to solve this error. Thanks a lot.
Microsoft Office Document Customization
This document contains custom code that cannot be loaded because the location is not in your trusted locations list:
If you trust this document you can save and open it from a location on your computer. For...
Read moreHi Pro experts,
After the successful installation and upgrade of Microsoft Word in the computer, I ended up with an error message. I am not able to open a document because of this error. The error says it has a problem with its contents. In addition, it says that the name in the end tag of element must match the element type in the start tag. How do I fix this error? Please help. Thanks in advance.
Microsoft Word
We’re sorry....
Read moreHello all,
I got an error message when I try to compile a requested file in the Microsoft SharePoint project. To my knowledge I did not face any problem while installation and setup in the computer. Is the problem regarding troubleshoot? How do I fix the troubleshoot problem errors? Please help.
Thanks in advance.
Error
An error occurred during the compilation of the requested file, or one of its dependencies. ‘Microsoft.Office.Project.PWA.IDS’ does not contain a definition...
Read moreHello Tech experts,
I got a problem with Microsoft Word installation in the computer. When I try to open a new form, I ended up with an error message. The error says Word cannot open a new form. The form contains schema validation errors. How do I solve this error? Do I need to change any settings? Please help. Thanks.
Microsoft Word
The form contains schema validation error.
OK Hide Details
Read moreHi there,
When I try to open a PowerPoint presentation in Microsoft PowerPoint Web App, I got this warning error message. For your information, I have all the supported versions in the computer. Do I need to reinstall the Microsoft PowerPoint in the computer? Please help with some ideas, which do not allow any installation. Thanks a lot.
Sorry, but to open this presentation, your computer must be running a supported version of Microsoft...
Read moreHi there,
When I try to work with Microsoft Outlook and SharePoint, I got this error message. The problems triggered when try to sync task between SharePoint and the inbox, and work with them anywhere. How do I fix this issue? Please help me to resolve this error and to find solutions. Thanks a lot.
Sync Tasks with Microsoft Outlook
Sync tasks between SharePoint and your inbox, and work with them anywhere. Your changes show up in SharePoint....
Read moreHello Whizzes,
After setting up the windows operating system in the new computer, I started to install the Microsoft Office 2013 pack in the system. I got the setup error when I try to install the Microsoft Office language pack in the computer. Do I need to reinstall the pack again? Please help me. Your help is great.
Setup is unable to proceed due to the following error(s):
The installation of a Microsoft Office 2013 Language Pack requires that another Microsoft Office 2013 program be installed on your computer. An installation of Microsoft Project or Microsoft...
Read moreHello Expert friends,
After successful installation of Microsoft Word package in the computer, I got a problem with Plugin. I think the plugin is not installed properly. How do I correct this plugin problem? Is this need to be reinstalled again? Someone could help me to solve this error. Thanks for your help.
Mendeley Word Plugin Problem
The range cannot be deleted. (6028) in Microsoft Word For more help, please visit https://service.elsevier.com/app/home/supporthub/mendeley/
Read moreHi all,
I got this weird error message while I am trying to work in a project in SQL2012. The error appears while accessing the application in Adventure Works 2012. Do I need to change any setting in configuration? Does anyone know how to fix this problem? Please help. Thanks.
External Data Refresh Failed
An error occurred while accessing application id AdventureWorks from Secure Store Service. The following connections failed to refresh.
SQL2012B AdventureWorks2012
vEmployee
Learn more about data refresh
Read moreHello,
The installation of TechNet copy for Microsoft office was successful. However, the error pops up when I try to use the ready template in Microsoft Office. I get this error message; the error says, “Something went wrong while downloading your template. Event flyer”. Please suggest me some solution to fix the problem. Thanks a lot.
Event flyer
Back
Read more
