Archive
Dear friends,
When I open my Laptop in the morning sometime I am getting the following error message: Outlook Data File " Archive folder " not closed properly it will be checked for errors Could you advise
Thanks
Grace
Read moreOn the various occasions I’ve worked from home, I’ve tried to access my email via the WEBmail thing when I’ve not needed to access files on the server. However, I don’t seem to be able to log onto it. When I type in my domainuser name and my usual password, I get the message that it cannot find a mailbox for ICAland. It then says to contact technical support telling them the following,
“The mailbox may be stored on a Microsoft Exchange 2000 or Microsoft Exchange 2003 server, or the Active Directory user account was created recently and has not...
Read moreHi All,
How can I add my picture in techyv.com
I was just wondering how can I add my image.
What are the different ways to add my image in this site?
Read moreI have an iPAQ Pocket PC which I tried to synchronize with my Windows PC when I got this error as posted below.
I’ve seen this error also when I installed Personal Folders Backup Utility.
My question now is how I can fix this?
I tried to search for the folders as stated in the error message but I was unable to locate it.
Please help.
Microsoft Outlook Synchronization
ActiveSync cannot log on to Microsoft Outlook. Make sure Microsoft Outlook is installed and functioning correctly. You may need to restart your computer. You could have a conflict due to two folders...
Read moreI used T-Mobile myTouch 4G by HTC with Gingerbread OS. I got this error when using the Mail App. I can access my mails but I could not open any attachments. I am under charter.net when I received this error. When clicking on Force close, the Mail App will close. Can someone help?
Sorry!
Mail has stopped unexpectedly.
Please tell HTC about this problem.
To help HTC improve Mail, select "Tell HTC" to send an error to HTC.
Force close Tell HTC
Read morei forgot my pc administrator password totally help me i use windows xp crystal edition help me please
Read moreI used the Mercurial software for my project. But I am having problem with the hg executable.
I am certain that I installed the mercurial correctly on my Mac OS X Snow Leopard PC.
The path for the hg executable is in “/usr/local/bin/hg” according to the error message, but the path seems to be not valid.
How can I correct this issue?
Select Path
"/usr/local/bin/hg" doesn't appear to be a valid hg executable
OK
Read moreI need to install SMART Bridgit Conferencing Software but I encountered an error with OpenSSL. The installation stops and when I attempt to start again, the same error appears. How can I fix this? It seems to be a common error but I could not continue with the installation with this. Please help.
OpenSSL.exe
OpenSSL.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem
We have created an error report...
I am getting spool error message on Eudora simultaneously. This happens when downloading email. Eudora stops working when this error appears and it will just o back to its normal state when clicking on the OK button. And also, I can’t seem to download emails correctly. It is very slow even though the email contains no attachments. And because of this error, I always have duplicates on my messages when done with downloading. I tried to install Eudora 6 to no luck. How can I fix this? Help me please. I posted a screenshot similar to what I am...
Read moreI installed Clicker 5 in my Windows XP PC. I will use this for my kids since it is highly educational. After the installation, I was a bit excited to launch it. My kids and I were staring in front of my PC for a while. But we get disappointed because every time I open it, I am getting this error as posted below. I tried uninstalling and re-installing the software but still gets the same error message. How can I fix it?
Unexpected Error System.NullReferenceException
Clicker 5(version 5.25.2610.20706)
at Xceed.SmartUI.SmartControl.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message&...
Read more
