Archive
I am planning to implement the lotus notes send mail but unfortunately I am facing a weird error message.
Error Message as follows:
The expression On Click you entered as the even property setting produced
The following error: Event procedure declaration does not match description of even having the same name.
* The expression may not result in the name of a macro, the name of a user-defined function, or [Event Procedure].
* There may have been an error evaluating the function, event, or macro.
I shall welcome some help from anyone regarding...
Read moreAt present, I have started to see an error each time I use Outlook with reference to a btwapi.dll. I searched on Google about this dll and it shows that it is related to a Bluetooth software and that it could be malicious, the search also shows a large number of “downloads" ready to “fix” the dll error. I am very hesitant to download any of these for fear that it will make the condition worse.
“OUTLOOK.EXE – Entry Point Not Found
The procedure entry point ?SetOnOppOpenCallback@CWBtAPI@@QAE?AW4WBtRc@@P6AXPAXJQAEJJ@Z0@Z could not be located in the dynamic link library btwapi.dll.”
This is a screenshot of...
Read more
I have initiated an installation of reQall for Outlook 1.2.0 and faced the message that says no supported Outlook is installed [Outlook 2010 beta (32/64 bit), 2007, 2003, 2002 or 2000]
Let me start by telling you that I have Outlook 2010 beta installed and functional.
Is this what’s causing the error?
What should be done now?
Thanks for any help.
reQall for Outlook 1.2.0 Setup
No supported Outlook is installed [Outlook 2010 beta (32/64 bit), 2007, 2003, 2002 or 2000]
OK
Read moreHi,
I have a problem regarding my Outlook 2007 system (12.0.6548.3001) SP2 MSO (12.0.6545.5004). I installed a VSTO add-in which is a custom form for outlook mails, and I want to remove it but have been unable to.
If you’d like to see my add-in, it is located here:
https://skydrive.live.com/?cid=0fc10220298ee711&id=FC10220298EE711!1147&sc=documents
I created this add-in so that I will have a customized email compose window, instead of using the default in outlook. The "New FormRegion1" menu option show as Actions, everything is still ok.
After that I went to Tools -> TrustCenter-> Add-ins -> Manage COM Add-ins, check the OutlookAddIn5 and started the process...
Read moreI encountered an error message just after starting Microsoft Outlook on Windows Vista along with the Enterprise Vault (EV) 2007 Outlook Add-in installed. This is the error message:
Microsoft Outlook has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Why does this happen? Can it still be fixed? Is this a bug in MS Office that hasn’t been resolved yet?
Any help will be greatly appreciated.
Error:
A problem caused the program to stop working correctly. Windows will close the...
On my way to register my Trend Micro Internet Security, Trend Micro Internet Security Pro, or Trend Micro Antivirus plus AntiSpyWare, I encountered the error message stated as follows:
Unable to contact Trend Micro. Please reconnect this computer to the Internet immediately to activate your software. If you can successfully open Web sites and receive email but still received this warning, then scheduled Trend Micro server maintenance has prevented you from activating Trend Micro Internet Security Pro. Please wait forty-five minutes before trying again.
Well, I waited for the designated time, and made sure that I was...
Read moreAs I was trying to install the Microsoft security essentials, I encountered this error message “0×80070643″ Installation encountered a problem.
Can’t complete the Microsoft Security Essentials Installation Wizard
Error code:0x80070643
I also tried to install the Symantec Endpoint Protection as well but faced this error:
The system administrator has set policies to prevent this installation.
VMware Product Installation
Read more
I got an app for Windows 7, and after the installation process I could see that the app, ThinApp was successfully installed.
At present when I try to login by providing the username and password so that I can connect to a DB server I get this error message:
"Error Message-76, File Not Found:...DLLInstallationUtil.dll"
As soon as I encountered this message, I got a copy of the "InstallationUtil.dll" from another machine where it was working and pasted in the VMwareThinApp essential location, but in spite of this I have the same problem.
Any advice will be appreciated.
Read moreI tried to upgrade/install a Fedora software package using Add/Remove Software on Fedora 10, and I get the error message below:
No package cache is available.
The package list needs to be rebuilt, This should have been done by the backend automatically.
More details
Cannot retrieve repository metadata (repomd.xml) for repository: fedora. Please verify its path and try again
X.close
Why is this happening?
Can anybody...
Read more
I am facing a problem regarding Windows XP at present.
I have tried my best to solve the problem, but I am afraid that the situation is worse than before.
Right now my system will not permit two things
a) Welcome Screen is unable to be shown
b) Several kind of software are not to being installed
a) Problem a happened all the way through problem b. To try to solve the issue of unable to install software, I used the system restore option. I used this along with a Windows 'vista theme', which altered the look of...
