Archive
How can we transfer a tablespace from one location to another location. I need to transfer some in my environment.
Thank you.
Read more
i'm using thunderbird for all my inboxes. i have set up 3accounts. Sometime it doesn't mark the emails I have already read as read. Why is this? This is really annoying.
Read more
Hi could you please teach me how to remove the html codes in java please?i know everything between < and > are html codes can i use StringTokenizer? how ?
Read more
I have fingerprint login on my windows 7 laptop. I got a little cut on my finger and now the idiot PC says that i am not authorized to login. What should i do ??
Read more
I am new to this technology.How we can verify whether the Active directory installation is proper or not?
Read more
recently, I got my monthly bill and I have been overcharged for the month for internet. I use a wifi router and I have put a password. But think someone is trying to access it without my knowledge. What are the options i have?
Read more
I have a laptop compaq CQ60. I have a terrible problem i can't work on it for a long time it heats up quickly. What are the solutions I can go for? I already have a fan.
Read more
Hi. I have a laptop hp G5040ea. This laptop had 1 GB ram (512+512) in the beginning. I removed the one and replaced it with a 2GB ram. So, now it has 2,5 GB. My question is what will happen if I replace the second ram with another 2GB ram, so I have 4 GB. Is there any chance I burn it?
Or it just won't work. In the instructions it says that it can have only 2GB memory but I increased it to 2,5 so far and it seems to work fine. I would be interested in your opinions.
Read more
I have been going through and updating our engineers to 2012 LT and have run into a problem with one of our engineers. After rebooting the machine, AutoCAD 2012 LT works perfectly for a brief time, maybe an hour or two. Then if you close AutoCAD and try to open again after this period, you get the following .
AutoCAD LT Error Aborting
There is a problem with the installation and AutoCAD LT cannot continue.
This error may occur if the registry software has removed or altered keys that are required to run AutoCAD LT.
To restore the required registry...
Read more
when my HP D1560 printer is refilled it always gives me an error message saying that "No cartridge is found".
I can't print. Please help me on this
Read more
