Archive
Each time I boot my PC, Windows gives a “Windows protection error while installing Device” message. Restarting the computer or reinstalling the software does not help
Read moreHow do I prevent the Task Scheduler from loading at startup?
Is any software available for removing shortcuts of programs at startup?
My Windows Explorer opens at startup even if there is no shortcut in startup folder.
Read moreHi experts
When I want to open a Microsoft Office 2010 application, I get the following message:
“Your beta software has expired.
Use Add or Remove Programs in Control Panel to remove the beta software from your computer.” I need a solution.
Please help.
Thanks a lot.
Read more
I use Outlook Express as my mail client. When I send graphics files as attachments to my friends who have Web-based e-mail accounts, the attached files are not displayed as part of the message. The files have to be downloaded to be viewed. Is there some way I can send pictures files from outlook express so that they are displayed as part of the message, just as in Outlook Express?
Read more
I am a novice when it comes to installing an Operating System. I am currently running Windows 7 and I am thinking of installing Ubuntu along with Windows 7. I would like some expert suggestions on how to go about it and also what could some of the potential problems that have to troubleshoot.
Read more
Hi, i get the above error image
Hello, my Dell XPS M1530 laptop was using Windows Vista but I changed the Windows to Windows 7.
The window 7 functioned well for a period. my USB mouse functioning normally for a day or so but when I plugged in a memory stick, all the USB ports stopped responding, and Windows is unable to recognize any USB device still now.
I think this may be a problem about out-of-date drivers, I have downloaded all the important drivers, and I am following the procedure to install them. i installed Notebook System Software, but...
Read moreI am using Total Video Converter and I boot registry code. It's working good but while I'm try to convert a .VOB movie file to .3gp on its default setting and click to start convert every time it's give me a error message called "Error while opening codec for output stream - #0.0". How can I solve this type of problem and how to convert .VOB to .3gp file?
Read moreWhile trying to install Microsoft security essentials I found the error message “0×80070643″ Installation encountered a problem. below is the error image
i tried Symantec Endpoint Protection too but got the below error image.
Error:
Can't complete the Microsoft Security Essentials Installation Wizard an error has prevented Microsoft security essentials installation wizard from continuing. Please restart your computer and try again. Vmware Product Installation The system administrator has set policies to prevent this installation.
kindly assist
Read moreHello experts,
I am using Vista home premium. My MS outlook 2007 was performing just fine two days ago and now it won't responding and when I log i to my computer to check email get the following message:
"Cannot start Microsoft Office Outlook. Cannot open the Outlook window. The set of folders cannot be opened. Errors have been detected in the file C:Documents and SettingsHP_AdministratorLocal SettingsApplication DataMicrosoftOutlookOutlook.pst. Quit Outlook and all mail enabled applications, and then use the inbox repair too (Scanst.exe) to diagnose and repair errors in the file. For more information go to the inbox repair...
When installing software I get the following error message
This software has not passed Windows Logo testing,
Does this mean the software danger?.
Also, should I continue with the installation or what should i click the continue anyway button
kindly assist help me with appropriate suggestions.
Thankful for help.
the below is the error image
Software Installation Error:
The software you are installing has not passed Windows Logo testing to verify its compatibility with Windows XP.
Continuing your installation of this software may impair or destabilize the correct operation of your system either immediately or in the future. Microsoft strongly recommends that you...
Read more
