Archive
Any help that you could offer me please! This is actually the problem of my friend about his PC when he mounted an external hard drive into it. When the command window asked him to restart the PC, he restarted it. During the booting process, the following error message appeared “0x000000F4 (0x00000003, 0x8A56ABE0, 0x8A56AD54,0x80604418) PERFORMING PHYSICAL MEMORY DUMP.”
And so I presumed that the problem is in the internal memory of the computer. Then, I opened the chassis of the system unit and mounted out the two RAMs and installed it again. I restarted the PC, but the same error...
Read more
My mother’s assigned PC in their office has been experiencing a very low performance and it took a long time to open any application installed on it. Just last week, it responded very slowly and the message appeared when she started it one morning to start her daily job routine “Your system is running with too little virtual memory. ”
The dreary presence of the of the mentioned message and the very slow performance of the PC most of the time force my mother to end the process, end the program that are opened and shutdown the Microsoft Windows and...
Read more
I need an urgent help please! I have installed Windows XP into my PC with ASUS K8V SE Deluxe as motherboard. Everything was working properly until yesterday when the following error was displayed in the computer screen “CPU Fan Error! Press F1 to continue.”
Therefore, I opened the computer chassis, checked the fan and I discovered that its sound is louder compared before.
I pressed F1 as what the message had directed me to do and it worked very fine.
The only thing that I don’t like is it happens every time I started my PC. It makes me feel uncomfortable always.
Is...
Read more
I was accessing the Internet Explorer (IE) when the following strange message error of my PC appeared on the screen saying “error loading c:windowssystem32inetcpl.cpl. The specified module can’t be found.” My father who has a background in computer troubleshooting offered a hand to resolve the problem. According to him, the error was caused by the computer viruses that damaged the internal files of my personal computer.
And so, he applied the full scan to all the hard drives on my laptop but there was no virus or threat found. Therefore, he uninstalled the IE, restarted the laptop and installed it...
Read more
My son’s laptop had experienced the message error “Error loading E6F1873B.DLL” every time he started it. Before the bothersome error happened, he downloaded numerous music videos from the internet. Everything was doing fine but after several hours had passed the computer rebooted by its own and the error message appeared already.
Additionally, during the booting process, it checked the hard drives and said that the hard drive checking is failed and it went back to the above error message. He restarted his laptop for the last time and the same error had been displaying in the laptop’s screen.
Can you please...
Read more
Hi Techs,
I do not know if any one of you are familiar with the software Acoustica. It is a program in which you can record music whether it be acoustic, then you can blend your own voice with it.I am using a headset with it. I tried recording. I am singing and all along, it is not actually capturing my voice.I tried it in a call, specifically in Gtalk, but unfortunately, my friend on the other line cannot hear me.
Well, first and foremost, I made sure that I am not on mute. I do not have another headset to...
Read more
I have run sfc /scan now on command prompt to check and ensure if there’s an error with my Windows XP Professional. But when I typed on the command prompt, nothing happens. I opened the Run command then type cmd on it, then type the exact command sfc /scan now.  I tried doing it as the administrator but nothing happened. Every time I hit the enter key, the cursor will go down but it is not scanning. I tried to reset the SFC to its default, by typing sfc /scannow REVERT, but it does not change a thing.  Sometimes...
Read more
I am really having a bad day. My laptop cannot be used. My little brother splashed a glass of water on it. I dried it with a cloth and tried turning it on with just a battery, it won’t work. So I tried turning it on using the power adapter and too bad it would not turn on as well.
I am so irritated about what happened. I need all my files in my laptop and I also don’t want to buy a new one. For me, it is not practical. I want to know if I can use a drier...
Read more
I made a fresh install of my operating system due to a conflict on my antivirus and my internet connection. I could not figure out what the problem is and there are lot of errors on my computer so I made a clean install.
I am running a Windows 7 Ultimate x64, with 320 GB Hard Disk and 2 GB of RAM. I have a partition before but intended to delete the other partition to lessen the errors I am receiving. After the installation, I installed the applications, software’s, messenger and browser needed. But an error appeared upon opening an...
Read more
I encountered this issue when I finished rebooting the computer.
The old operating system that has been installed was Windows 98, and I installed a new Windows XP but when I start the computer after rebooting the computer, the flash message on the screen remains as "Missing operating system" .
I checked the boot devices, and it is placed correctly. I restarted the computer again but still the issue came out. I reinstalled the operating system, and it normally run, and loads the OS. Turned the computer on and waited for a couple of minutes, but then...
Read more
