Archive
I am having trouble with amount calculation in C#. I am doing an invoice program in C#. When I store a value and retrieve it back, the decimal values get rounded or an additional cent come in! I can not figure it out. I think the problem is with the data types that I am using.
Read more
Hi there,
I have developed an Excel VB sheet to generate transcripts. The application is simple. But I don't know how to print the page with macro. Currently, I just copy-paste the generated transcript to Word and print it manually. This is not looking much professional. So  I would like to make it automated.
Please help.
Read more
Hi everyone,
I am using MS windows XP and having an issue with MS outlook express. I have MS outlook express 2003. The issue which has been faced by me is that whenever I want to exit OE or switch identities which I have created in it, I use to receive a specific message which is ” To free up disk space. Outlook Express can compact messages.
This may take several minutes.
To get rid of this problem I firstly clicked on the “ Do not show this message again” dialog and clicked cancel but OE continues to show the same message...
Read more
I am using Windows 7 and I need a security system for my PC as I want to keep my things pretty private, so how can I do it? I use Windows 7 ultimate version. Is there any built in software to give that much security for me? I have heard about voice recognition system but can I use it in Windows 7? If I can, then how can I implement this system into my PC or is there any other system in Windows to implement it?
Voice recognition is a secure way to keep things secure in a PC....
Read more
I've reinstalled Windows 7 Ultimate (32bit) recently, and once I had everything set up (additional apps, preferences, etc.). I found out about a new problem with the PC Suite software. Once I try to connect the phone (Vivaz Pro) via USB (in PC Suite mode), Windows immediately recognizes the device (and the phone starts charging), but PC Suite says "device couldn't be recognized".
I've tried restarting the phone & computer, uninstalling and reinstalling PC Suite, using both an original and a newly purchased USB cable, using another USB port, and even REINSTALLING WINDOWS 7 TWICE, but it keeps coming up with...
Read more
Whenever I insert a blank CD-Rom.
Windows Vista asks me what type of a CD to create.
Why is this ?
Read more
How to group data by month when using a date time column in MySQL? I want to produce a report, to group the results by month. The table has a column for which the data type is DateTime. How to use it, to get the results by month?
Read more
I had this problem since the other day and still looking for ways to solve this. I hope I came into the right site to give me a good advice with my problem.
I used to open many programs, such as Online Games, music player, browsing and chatting, but now my PC turns off suddenly. One thing that came up to my mind is overheat, so I tried opening the side cover of the CPU and put my electric fan in front and leave it for few hour.
Then I turned on the PC again, at first everything goes well and...
Read more
I am using Microsoft windows XP sp2. I am having a wired problem with my mouse. I have a laser USB mouse which is not working properly anymore. Actually, yesterday I was using my PC and suddenly it turned off because power was gone. Before that each and every hardware component of my PC was working fine but after that when I turned-on it there was a problem popping-up in the task bar that my USB mouse device is not working properly.
This is very shocking and irritating for me.
To handle this issue I firstly totally un-installed the USB...
Read more
Hello everyone,
I am having a hardware problem. I have an issue with my monitor and the issue is that, my monitor is not displaying the output. In-fact I was using my monitor and all of a sudden my PC was jammed.
I waited for a while, hoping that my PC will run smoothly again, but it didn’t work. For that, I restarted my computer to fix the issue but then my monitor was not working.
To solve this issue, I first of all opened the case of my Central Processing Unit to see whether every thing was working fine or not?...
Read more
