Archive
I have installed two operating system on my PC.Windows XP(SP3) on C drive and windows 7 on D drive.
Every time when I go to start my PC it takes much time to start up and ask me which windows I want to open.
It is disgusting.
Now I want to remove Windows 7 from D drive.Can anyone help me please?
I don't know how to boot up windows.
Also help me on this issue.
Read moreEvery time that I open my PC there's a window that pop's up saying that my Antivirus is out dated. But whenever I clicked on update it just keeps saying that it cannot update.
How can I update my Antivirus?
I have the license till June 2011.
Read moreWhile I was browsing the internet, my computer suddenly restarted. The windows logo and loading bar appears, but afterwards it brings me to a black screen with error similar to this:
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this.
Safe mode with networking.
When I try to choose from any of the above choices, it just brings me to the same...
Read moreA blue screen of death or BSOD in short, often occurs when your computer encounter viruses or if suddenly there is a changes or deletion in your registry files.
A bootup failure may occur when you encounter this BSOD. For sort of reason, BSOD happens all the time, especially if you're using windows. There is always a chances that you'll experience this blue screen or Stop Error whenever a windows senses...
Anyone interested to fix the problem please view this post.
My flashdrive has been corrupted. It all started when i went to internet cafe and have some research. I insert the flashdrive onto the USB port of the computer. When i finished and got home I open my computer and check my flashdrive if the files that i have saved was there. When i open the flasdrive, it contains empty files?!!! It shocks me, because all of my important documents are in their and the sad thing also is i did not create a back up file. It really sucks...
Read moreHi the question I am asking is related to Photoshop CS3 crop tool. Actually I want to crop an area from an image. The crop area is very large in length but pretty small in the width the problem is that the crop tool won’t allow me to crop rectangular areas as the guides are locked to only select areas in specific sizes. I also checked the tool setting but they have options like 5x3 inches and 8x10 inches etc. but there is none that would allow me to crop a thin strip from an image. Can someone help...
Read more
I'm an entrepreneur and have a small business. I am planning to put up a commercial building with 2 story building. 2 rooms in each floor so 4 rooms all in all. I will put each room a personal computer at least 2 units. And i am using the 3 computers with Windows XP for the OS and Windows Server for 2003 for the 1 computer which I will be using.
Now, the 3 computers have already installed the Windows XP OS. But the 1 unit has not been installed for Windows Server 2003 for the reason that...
Hello everyone!
I have a serious problem here please help me find the problem.
I was installing WINDOWS XP yesterday. I properly boot the boot priority device and successfully loaded the Windows on the desktop. When I install the drivers, the screen prompted me "error" and when I check in the device manager I found this "Intel (R) High Definition Audio HDMI (?)"
What does this mean? Is it the audio driver not compatible with the Windows XP? I really don't get the point of this. I have already searched for the solution thru online but I didn't see possible solutions.
Is there a problem with my computer or just the driver?
Please anyone can share their ideas feel free to answer.
Thank You.
Paul...
Read moreI am new to PowerShell and have been given a script to run it. I tried running and get this message. Is it a version issue I have V1.0 and running it on windows 2008 Operating system.
Administrator: Windows PowerShell Modules
PS D:> .runthis.ps1
File D:runthis.ps1 cannot be loaded because the execution of scripts is disabled on this system. Please see "get-help about_signing" for more details.
At line:1 char:14
+ .runthis.ps1 <<<<
+ CategoryInfo : NotSpecified: (:) , PSSecurityException
+ FullyQualifiedErrorId : RuntimeException
PS D:> _
Can anyone help me please ?
Read moreMY Laptop is a bit older but I use Windows XP professional version 2002 which is service pack 3 and,
