Archive
Last month I had an issue regarding in playing online games which I never had before, it consists of accentuated decrease in the FPS rate which is impossible to keep playing. I’m doubtful that it is due to my connection because I used to play with no hassles. And so I spent whole day to reinstall programs and restore to its factory definitions, but the problem still persists.
Anyway I’m using Acer Aspire 5737z with a graphic card NVIDIA GeForce 9400M G. Here’s the scenario:
As soon as I start the game the fps rate is about 60 which I think...
Read more
I am facing a problem that I have downloaded some YouTube Videos (.flv) media files on my computer but I am unable to rename, delete or move the file to another folder of my computer. I can copy or play the file but it doesn’t allow me to do anything else.
The “READ ONLY” field is not checked in the properties. And I don’t know why I am unable to even change any of the properties. Whenever I tried to change the properties it displays a warning message “Access Denied”. And sometimes it shows me “Cannot delete file...
I have an over 1 year old assembled computer with a 32-bit Windows 7 operating system. It has been working fine until lately, it would not power on. Initially, I was having problem turning on the computer by pressing the power button. I would try to press it many times but the computer would not initialize nor would it create noisy/beep. Most of the times, the computer would start after several attempts of pressing the button. But today, I am pressing on the power button for over an hour now and still no go!
I have tried switching the power...
Read more
I am currently using a dual core unit with windows XP installed on it. My unit does not have a wireless network so whenever I try to connect to the internet I have to keep it wired. So I decided to buy a NetGear 54 Mbps Wireless PCI Adapter (model: WG311v3). I successfully installed it at the back of my CPU according to the instructions in the manual. But the problem is, when I turn on my computer, I began hearing beeps and the pc did not boot or display anything on the screen.
I can see the...
I bought a brand new iPhone 4, a couple of months ago. It has been working perfectly, but two days ago it developed a weird camera complication. Whenever, I take a photo a white spot appears and the same spot appears on every picture. This only happened on the picture mode and not on the video mode.
I first thought the protective plastic sheet was the problem. I removed it but nothing changed. The pictures still had a white spot. I went to the extent of opening the gadget up and try to do some cleaning and fixing. I came...
Read moreAt home I use windows XP and Windows Server 2003 operating system. Often I use Windows Server .Every time I use Windows XP operating system, but the problem is that a have a USB drive, my USB drive work ok on my office PC, and also on my home PC when I work in Windows Server 2003 but it does not work in windows XP, I try it same port when use windows XP and Windows Server, I use license copy antivirus, sometimes my pen drive work ok on Windows XP and occasionally can’t work what’s the problem how can I...
Read more
My friend ask me to help him to set a network in the internet cafe. We're having an argument if we will use DHCP or Static IP network. He wants to use DHCP but I insisted, I suggest Static network because I myself don't know how to configure DHCP in the network. And he doesn't know how to set DHCP network also.
Our problem is how to set DHCP in IP network. Is this capable for a 4 working stations? How can we set DHCP?
Is anyone there having an idea for this one?
Versatile solutions are appreciated. Post your answer!
Thank You.
Read more
I am working in Windows XP, and others my colleagues use Windows 7 and someone else uses Windows Server 2003 or Windows 7. Sometimes I need to access network drive such as c drive, d drive e drive etc. without manually sharing this drive. Usually I can access all network drives but can’t access this on the computer which is running on Windows 7.
I try to access Windows 7 computers C drive by administrative password, but can’t access. So please help me how to access? My network is OK and no firewall is on that computer.
Read moreYou have a broadband internet connection, and I am using this internet connection through the broadband, to do the following access email and the web from your own PC.
The kids are getting bigger and are starting to use laptops, due to their increased need to use social networks and do some homework. So now we all want to use the web at the same time. I want about 5 computers to share the net at the same time.
I also use the laptop connected with the broadband.
The question is, how can all those computers be made to share the internet...
Read moreHi,
