Laptop could not connect to internet wirelessly
You have to setup or configure your wireless router, in order to synchronize their settings. Especially the IP address, the Gateway and the DNS which were given to you, by your ISP provider and especially check if your router is setup with the SSID.
It should be same as your settings in your wireless setup.
Thanks for the help.
