Exchange problem ..not sending internet emails
Asked By 7060 points N/A Posted on -
I had to re-install my exchange server.  I did so with no problems but I am not receiving my internet e-mail through it.  I'm getting nothing.  I'm not even getting any error messages.  Can someone help me?
Thanks,
Answered By 590495 points N/A #82594
If you are not getting anything through your Microsoft Exchange server, try checking the settings. Check if the POP3 and SMTP servers are correctly entered without any typographical errors. Check also your username and password if they are all correct. If there seems to be no problem with any of these informations, try deleting your username and password and then save it so these categories will have null values. Your password might have gotten corrupted and deleting it will remove it. Enter your username and password again then save it then try again if you can now receive an email. You can do a test by sending a sample message to your email address.
