Archive
I encounter a crash whenever I try to open a file on Microstation V8i and an error pop up appears informing that Microstation has stopped working and it would notify me if a solution is found. I tried the following steps to fix this issue: I checked the location path of the folder dwgdata, pointed to by the variable MS_DWGDATA. Here I searched for the file MstnShxFileList.csv andon finding this file, I renamed it to MstnShxFileList.bak. Now I try launching Microstation only to find this error still refusing to go away. Now what else could be causing the problem...
Read moreHello Everyone.
I wish someone could help me with this error I am getting when emailing photos using Picasa. I am trying to email photos using Google mail and I get a message that says this account is not enabled. I try opening the web page to resolve the issue and tried these steps to fix the problem: I checked my internet connectivity and having found no issues there, tried selecting the photo from and desktop and using ‘Send To Mail Recipient’ tried mailing the photo. This did not succeed. I attempted disabling my firewall temporarily and then mailing again....
Read moreHello Everyone,
I have been attempting to make use of my Detail Components in AutoCAD Architecture 2012 but when I open the Detail Component Manager, I am greeted with this error message that says the detail component databases are not specified. I tried to fix this issue by accessing the detail database from the tool palette and trying to point it to the correct path. This I achieved by opening OPTIONS dialog box from command line and clicking the Add/Remove button in the Detail component database to navigate to the path C:ProgramDataAutodeskACA 2012enuDetailsDetails (US) .Lastly I closed the options dialog...
Read moreI am using Chrome in my Mac PC. It was working fine for the past months until today. Most of the pages that I tried to accessed received this error message: Error 105 The server could not be found. How can I fix this error as it keeps bugging me for so many hours now? Any help will be appreciated. Thank you.
I get a failed to connect to iTunes store message every time I try to connect. The error popup suggests checking if the network connection is active and to try again. I ensured that my network connection is working fine and did not find any issues with the connection speed either. I tried connecting few times but always received this error. I even tried checking my keychain by selecting Keychain First Aid from Keychain Access in Utilities. But it did not report any problems. I am working on a Mountain Lion 10.8.5 Mac and as far as I...
Read moreHi,
I upgraded to AutoCAD 2013 yesterday and I suddenly find myself pestered by a silly pop up message. I tried to assign a pallet orientation to Quickcalculator on the CUI editor and then save my workspace and exit. I tried launching AutoCAD again and I get the unhandled exception shown below. This error occurs irrespective of the left or right pallet orientation assigned. If try to click continue, Quickcalculator is no longer docked and it floats around. I have never seen this happen in AutoCAD 2012. I tried resetting AutoCAD to default settings and tried to recreate the scenario....
Read moreHi there,
Song editing makes me wacky sometime. When I was doing some sort of research in Peak Pro, I ended up with this error. I never experienced this before, ‘File not found’ I have all my files. But still I hit the continue button, It says there is no enough space. I have plenty of empty space left in the disk, why this error appears? Or the file is corrupted? Any help will be great. Thanks
Error Image
Words in the Error Image
Macintosh Error -43
File not found. Creating temporary file.
Read moreHi Brainy,
I planned to update by Solidworks 2011 to the latest one when I try to Upgrade, it failed in between leaving an error message.I have a Windows XP operating system previous version is working to the core. But I don’t understand why this error is. This message provided me the installation log files as a zip file, friends if you want I can able to attach them. Need your help badly.
Error Image
SolidWorks Installation Manager
Internal Error: The Windows Installer for this product component did not run as expected: FEATURSTATE.
Contact Technical Support.
When...
Read more
Hi Friends,
I have completed installing ArchiCAD 13 and when trying to launch, it doesn’t start and gives an error. I am running windows Vista 64 bit and as far as I know, all the software on my machine is up to date. Is this an error with the installer? I try downloading with a fresh installer and I still get this error even though the download completes without errors and the installation too proceeds smoothly. I attempted downloading VBUtils.dll file. Restarted my computer and tried to perform the installation again. Still I seem to have no luck. What could...
Read moreHi,
I have just completed another unsuccessful attempt at installing Kaspersky Internet Security 2013 and am at my wits end as to what more to do. Here is my problem: Every time I try to install the application, I end up with this message that says the installation has failed due to a network error and the error code is 1316. I tried using the removal tool in safe mode to uninstall and then trying to install again. But still this problem persists. I was offered further tip from Google which said I had to run the tool in safe...
Read more
