Archive
Questions:
Hello All,
I am trying to download and install the Corel Painter Essentials 4 on my new Bamboo CTH-670. I find that the download completes without any problem. But I cannot install the application using this downloaded exe file. When I attempt running the setup file, it shows the first screen preparing to install and then as soon as I click on the Install button it gives me following error message. The complete error message is shown in the attached screenshot below. I thought this might be a problem with installer and I tried downloading from a different link. But...
Read more
Hello Experts,
I have been doing this painting on the standard ArtRage canvas for the last two days. And while working I tried to playback the recorded script from time to time on my Mac to test the resolution and it worked fine. Once I completed the work, I attempted playing the script once again and now when I get past 80%, it stops and gives an error message and the playback gets stuck.I can only force quit to get rid of this error. I tried duplicating the painting and resending it for playback found the error happening again. I...
Read more
Hello Friends,
I recently bought PhotoPlus X6 and I am having trouble installing it. It keeps giving this error message. I've tried several different things to resolve this issue but did not get any closer to installing it. I found a similar error although with an error code 1935 specified being thrown when installing several Microsoft products. I thought I’ll give the steps mentioned a try and went about doing the following: The Support website informs me that this error usually happens when there are third party programs running in the background and one must remove them to complete installation....
Read more
Hi Pals,
I have downloaded the Corel Painter Essentials 4 and find that I get an error stating that the archive is damaged or is an unknown format when I double-click the downloaded exe file and the extraction fails. I thought this error may be related to unpacking of the file on my machine. And to work around this problem, I tried renaming the downloaded exe as a zip and then unpacking it into a new folder. Then I attempted running the setup directly from this new folder. However this does not seem to fix the issue. I tried downloading...
Read moreI am attempting to update my iPhone but there is a gray error box that will appear with a message, "There was a problem downloading the software for the iPhone. An unknown error occurred (9006). Make sure your network settings are correct and your network connection is active or try again later." I tried again after some time but it's still the same. Is this an issue with my connection? Please send me some ideas on how to fix it. Thank you.
Hi Experts,
I am not able to install the AVS audio Editor on my computer using windows XP and I get the following error message claiming to have encountered an error while attempting to replace a file. I tried uninstalling and then reinstalling a couple of times. But this did not solve the issue. I am logged in as administrator and have full permissions on this machine as well. Then I used a clean utility to completely remove the traces of partially installed software and downloaded a fresh copy of the installer. I also manually verified that all the files...
Read moreMy Power Boost software suddenly stopped on working. And it always shows an error every time I try to launch it. The error is stating:
Power Boost
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
What could be the reason for this? I tried searching for some compatibility issue but I am sure that Power Boost is compatible with my system. Please help.
Read more
Hi Friends,
I recently downloaded the 60 day free trial of Capture NX2. I want to edit Nikon’s NEF Raw files but whenever I try to open an NEF file, Capture NX2 reports an error stating that it is not a valid file. I attempted opening by double clicking on file and trying to open from within Capture. However, this method fails to work too and I still end up unable to open any of the NEF files on Capture. I am using images shot using Nikon D5200 camera. I can’t think of any reason for these files to not...
Read more
Hello All,
A few days back I installed PagePlus X7 that came with Pro Template Collection: Home Improvement & Services. I could install PagePlus X7 without any issues. However, the template pack gives errors when attempting to install. I am using windows 7 Home Basic 32 bit version and McAfee internet security on my computer. I thought I’d give copying the disk to a local directory and installing from there a try. But on running the setup from the directory, I am greeted with the error again and the templates could not be installed. I get this error message as...
Read moreHi Everyone,
I have been trying to deploy Autodesk Building design Suite Premium 2012 on our server without much success. The deployment cannot be completed because of some insufficient access problem preventing the file from being written. I have attached the log file & error message screenshot along with this. I have already verified that the folder and share permissions have full write access on the server. I find from the logs that deployment fails with a fatal error when AutoDesk Sketchbook Designer is deploying. I don’t think this is a problem with just the sketchbook though as I when...
Read more
