Archive
Hello All,
I started using 3DS Max 2010 trial version a few days back and I have a problem with the unwrap button. Whenever I press the unwrap button, I get a licensing error displayed. I checked and verified that I have a valid trial license and I am well within the 14 day trial period. I tried uninstalling and reinstalling a couple of times and this did not improve my situation any further. Then I ensured that I logged in as administrator and disabled the firewall before installing and tried again. Installation completes without a glitch every time. But...
Read moreHi All,
I have been trying to install 3DS Max 2011 on my windows XP SP2 machine for about a dozen times now without any luck. Every time I attempt to install, I get this error message telling me that some of the components could not be updated now and that I should try again after rebooting. I have lost count of times I have tried this and needless to say all these attempts were futile. I fail to understand why I should be prevented from updating any components. For one thing there are no other programs running on this...
Read moreHello Friends,
I am a newbie trying out the 3DS Max 2011 and it would be very useful for me if someone could share how to export an XMF file in Max. I have been trying to export the XMF file of a table I drew and I am not able to complete this operation. I exported an XSF file of the same object and everything went fine. But with the XMF file I run into an error in step 2 and 3D Max exporter informed me that only a single mesh can be exported at a time. I decided...
Read moreHi Everyone,
I have been using CorelDraw X4 on my laptop for about 4 months now with windows 7 and everything worked smoothly until yesterday. But from today morning, I started getting a compile error while working with CorelDraw. Immediately after this error is displayed, it goes to debug mode and stops the program. And then it highlights OPTION EXPLICIT in the Objects section of the macro. The only change on my system today would be that I had installed a windows update last night and then shut down my computer. Could this update be causing the issue? As...
Read moreHello All,
I have been attempting to import a Maya Binary file into keyshot and am not allowed to so as Keyshot reports a Maya installation could not be found. Why is this being asked? I tried importing a couple of times but still I get this error. Is it necessary to have Maya 2011 or 2012 or 2013 version installed before importing a Maya file? That sounds surprising and an expensive way to get a feature working. I hoping there might me a better way to get this working. Please, can somebody help me with a workaround to stop...
Read moreHello,
I want to edit photos taken with my Canon EOS 450D camera using Photoshop CS3. But I have not been able to open these RAW files using Photoshop yet alone editing them. I have all the updates installed and my system has Camera RAW 4. It also displays the thumbnails of the images as shown in the icon that I have attached below. Yet when I try to open them, Photoshop gives an error stating that they are not the right kind of documents. Why won't my Photoshop open up RAW files? I find that there is a universal...
Read moreHello,
I am having a problem with writing DVDs on Nero 7. Every time when attempting to burn, the space gets occupied on the disk but nothing opens and I get the error shown in the following attachment. This is simply wasting my DVDs. I was able to work with this program only two days back without any issues and nothing has changed since then. I am using Sony DVD’s as I have always used. I also tried using DVD’s from Imation too this time. But I am not able to burn the DVDs properly. I am using 16x speeds...
Read moreHi
We are having some trouble with the AutoCAD 2010 software installed on our computers. It fails to work on all three computers we tried installing. As soon as you open a DWG drawing, the application simply crashes reporting ‘an unhandled access violation’ even if no other action is performed. We are using Windows XP on these machines and Norton Antivirus 2012. I tried installing all the updates available, but this did not help me to fix the problem. We have no prior versions of this software installed on any of the machines. What then could be causing the issue?...
Read moreHello Everyone,
I tried installing the Quark License Administrator 4.5 and downloaded the license file. Everything went smoothly and I restarted my system. But now I get an error message telling me that the port number the server is configured is in use. I tried to reinstall a couple of times, but this did not get anywhere near resolving the problem. I also tried using different ports to perform the installation but I did not get this problem resolved in any of the ports. I attempted running this on another Mac machine as well and still get this error. I...
Read moreHello,
I got a script along with 3DS Max 2010 named StereoCamModifier_v1_0.ms. I tried running it but I came across this error reporting a Fileln exception. The error seems to come up in the following line:
)lenameFile rendOutputFilename + _RIGHT" + "_" + (FrameToString (currenttime.frame as integer)) + getFilenameType rendOutputFilename"
I have no idea as to how to go about fixing this issue as I am totally new to this Stereoscopic procedure. If it is necessary, I can post the entire script here. Also I would like to learn how to work with the Stereoscopic. Can someone help me with its...
Read more
