Archive
Hi there,
I ran Far Cry 3 Updater and it says that the executable files do not exist. I have checked for the .exe icon and it is in the folder where the game is installed. Now I don’t know what the problem may be and can anyone help me to fix this ? Please tell me what is the main error with this game ?
Thank you !
Far Cry 3 Updater
Failed to execute command farcry3_d3d11l.exe (error 193) Please make sure this executable file exists.
Read moreHi All,
I am encountering a problem trying to load files into stack in Photoshop CS5. Every time I try to load, I get this error 22 saying windows does not have a constructor. I am using windows 7, 64 bit version on my machine. I tried temporarily removing all the third party plug-ins installed to see if any of them were causing an issue. But I still get this error. I have the latest update for Photoshop CS5 and windows 7 installed on my machine. Now what else can I try? Will it be required to uninstall and reinstall...
Read moreHello Experts,
I am facing a problem with the InDesign CS6 software installed on my client and server network. I am running Mac OS X 10.8.2 on my server and windows 7 on my client. InDesign works perfectly on my Mac but with the windows 7 client, InDesign crashes soon after opening an existing file from server or creating a new file and saving it to the server. It gives an error message stating that the network connection was lost for file or that the file is being modified by another process. I get this error both when logged in...
Read moreHello,
I was attempting to install the Adobe CS4 Master Collection via Casper today and am receiving this error message from Adobe AIR. ‘This application requires Adobe AIR to function. Please download the latest version of the runtime and then launch the application again.’ The error message also includes the link to adobe.com/go. Once this pop up appears, it halts the installer waiting for an input. And if I click OK, I get an empty Adobe After Effects CS4 folder. Again if you click OK, the message pops back again. Try clicking OK you get to see this same empty...
Read moreHi All,
I got the Photoshop CS3 downloaded on my laptop and am having a hard time installing it. The setup simply halts with a message that says an error has occurred and it offers no helpful hint as to what might be the problem. It simply says encountered an error and that is all it has to say. I have been trying to install several times now and unfailingly coming across this cryptic error message every time. I tried running a complete scan of my system using AVG and it did not report any issues. I am using windows...
Read moreHello,
I am trying to use a parameter FULLERS for images so as to enhance the quality of the preview generated in QuarkXpress. It is defined as FULLERS (true/false/none) and “none” causes the image preview to be generated at full resolution on QuarkXpress. This works perfectly for EPS or TIFF images. But with JPEG images I get the error message shown in the below attachment. It says the picture has a low resolution and can only get a low resolution display. I understand that JPEG is a supported format for full resolution. But when I try to select an item...
Read moreHello Everyone,
I really hope someone could help me with this really maddening issue. I have been attempting to render in the Render Queue and all of a sudden, all those sequences that had rendered perfectly earlier seems to hang around 1 or 2 frames and gives me the error message shown in the below attachment. I have made no changes to these items and I have had now new installations or updates done recently. I tried trashing all AE preference files and tried repairing permissions. But none of this worked for me. I am running After Effects CS5 on...
Read moreHi All,
I tried downloading and installing the 3DS Max 2013 Trial version two days back. I was able to complete the download without a hitch. But when I try installing, I run straight into this error message that is shown in the below attachment. I can’t make head or tail out of this message. As soon as the installation begins and proceeds a bit further, this error appears and everything stops. I have been trying to run the installer a couple of times. But I happen to get this error unfailingly ever since I tried this out. I am...
Read moreHi All
I have been working with quite a few files for my project on CorelDraw X5 and when attempting to open quite a few files, I started getting an error message reporting an invalid fill and giving me options to Abort, Retry or Ignore. I was not sure what could be the issue and clicked retry. But this again gave me the same error. I examined three files giving this error and found that they were all created using CorelDraw X3. So could this be a compatibility issue? Aren’t these files backward compatible? What changes should be made to...
Read moreHello,
I have been trying to add a border using Photshop CS5 but I end up getting this error message. Here is what I did: I created a new layer and selected the rectangle tool. Next, I go to Edit>Stroke and then I proceeded to set the parameters of the border as ‘1 pxl, inside’ and chose the color for border as blue. Then I clicked OK and got this error saying that there is nothing to stroke. What could wrong with my method? I have tried several times but always receive this error and have failed to figure out...
Read more
