Archive
Hi there,
When I want to install a small software downloaded from the internet this error told me that something might be wrong. I didn’t try to install it again because I am afraid that might harm my laptop. Can anyone explain me what is this all about? What this error means?
Thanks!
“US- 122 Installer” is damaged and can’t be opened. You should eject the disk Image.
“US- 122 Installer” is on the disk image “us122_osx_3_4_0 (1).dmg”. Google Chrome downloaded this disk image today at 17:19 from tascam .com.
Cancel Eject Disk Image
Read more
Hi there,
I tried to make an update, but this error popped-up. I searched to make a download from different servers but nothing useful was found. I am a bit new on Apple and I don’t have a much experience with this kind of errors. Please is anyone available to help fixing the mess I did?
Thank you!
MIDI_USB_OSX_3_2_2- 1.dmg
There may be a problem with this disk image. Are you sure you want to open it?
Opening this disk Image may make your computer less secure or cause other problems.
Open Don’t Open
Read more
This error message box pops-up suddenly and randomly on my desktop. Sometimes can be very annoying and I want to get rid of it as soon as possible. Can anyone of you guys help me to fix this?
Why I have this error and how can I prevent?
Thanks!
“M-Audio USB MIDI Uninstaller’ can’t be opened because it is from an unidentified developer.
Your security preferences allow Installation of only apps from the Mac App Store and identified developers.
Read more
I installed Virtual Dj to play a little bit, but I had this surprise made by this error. I tried different versions but all came with same error. My sound is working fine, this is the only error that I have at this moment. Is any expert available to help me fixing this error? Maybe you can explain me how can I avoid this kind of errors?
Thanks!
VirtuaIDJ
Error in the sound driver of CoreAudio: Your soundcard is probably not connected, or the settings are incorrect.
Ok
Read more
I made the update to my sound card and when I installed the new updates this error messed up all my PC starting with my sound. Now is not working at all and installing the old version not solving the problem. Please someone help me to fix this error and tell me why the new updates is not working?
Thanks!
Error
An unknown error occurred in the MOTU ASIO driver.#25, Error 25 .DriverHoster.cpp 882
OK
Read more
Hi there,
I downloaded the latest version for my audio hardware and I have this error. I don’t know why is saying that I need the latest version since this is the only one that I found it. Can anyone help me to fix this? You know any other ways to download the latest version of drivers?
Thanks!
Realtek High Definition Audio Driver
An error (-5009: 0002802b) has occurred while running the setup.
Please make sure you have finished any previous setup and closed other applications.
If the error still occurs, please contact your vendor: Realtek Semiconductor Corp.
Read more
Hello experts,
I have this error and I don’t know why. I was bored today and I thought maybe I can make some changes in my settings. Now my sound is not working and I don’t know how I can repair it. I am a newbie with the PCs I am stuck with this error. Please can anyone help me to fix this and repair my mistake?
Thank you!
Polac ASIO
Couldn’t locate FW-1082 driver
OK Cancel
Read more
Hi there,
After I have installed Medmont Studio this error appeared when I opened the program. Before the update of Windows 7 this program worked just fine. How can this error be solved without reinstalling my Windows 7 ?
Thank you !
An Unexpected error (COMException) has occurred while configuring Medmont Studio.
Description: The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail. (Exception from HRESULT:0x80073681)
Details of the error will be written to StudioConfigure.log
OK
Read more
Hi there,
I have updated my Windows 7 and I had to reinstall iTunes. Everything is working just fine except iTunes. I have this error when I try to connect my iPhone and I don’t know how this can be solved. I never had this error before and it worked fine. Can anyone help me to fix this error please? What is the problem with iTunes?
Thanks!
iTunes could not connect to this iPhone . An unknown error occurred (0xE8000084).
Read more
Hi there,
I can’t install Skype on my iPod because of this error. I don’t know how can this be solved or if this Skype version is OK for my iPod. I want to install it because all my friends are using Skype and I want to be close to them. Please help me to fix this error. Why I have difficulties to install it?
Thank you!
The iPhone “Mark’s iPhone” could not updated. An unknown error occurred (11).
Read more
