Archive
Hi there,
I cannot uninstall AutoCAD 2011 because of this error. I have deleted all the AutoCAD files from My Documents and is not working. I don’t know what to do anymore. Does anyone have any idea about this error ? What this means ?
Thanks !
Error 1324. The folder path ‘My Documents’ contains an invalid character.
Read more
This is the error when I want to schedule a scan to a certain dates and I really need to make this. I did a small research on the Internet and no solution was found. Can anyone help me please to fix this ? What should I do to prevent this ?
Thank you !
Advanced AVG Settings
Error during plugin loading. Schedules (0xE0018E02)
OK
Read more
I am trying to install Autodesk Infrastructure Design Suite Premium 2014 and I receive the same error every time. Also I cannot close this window and I have to open Task Manager to close the program. Can anyone help me please to fix this error ? How can I prevent this in the future ?
Thank you experts !
A software problem has caused AutoCAD to close unexpectedly. We apologize for the inconvenience this has caused you.
Read more
Hello experts,
I try to build a complete new Lync 2010 Enterprise and get this error after running the Prepare Schema option in the Deployment Wizard. I don’t know what I did wrong and how can I solve it. I’ve followed all the standard steps and still. Any solution ?
Thanks !
Error: The user is not member of “Schema Admins” group.
Read more
Hi there,
Lync Server 2013 gives me this message and I don’t really know what it means. I know that is not working anymore with all functions and I cannot start them. Does anyone have a solution ? What I did wrong and what is limiting the capacity ?
Thank you !
Lync Server 2013
Monitoring Dashboard
Report processing stopped because too many rows in summary tables are missing in the call detail recording the LcsCDR database.
Read more
AutoCAD Civil 3D 2012 Error Report- I have this windows every time when the program crashes and it started to happen more often. I cannot prevent this because I don’t know how so I am asking an expert from this website to help me. What shoul I do to get rid of this ?
Thank you !
A software problem has caused AutoCAD Civil 3D 2012 to close unexpectedly.
Read more
Hi experts,
I have this FLEXnet error every time when I want to open the inventory. I never had before any error cause by Autodesk Product Design Suite Premium 2013 and at this moment I don’t know how to manage them. Can anyone help me with this ?
Thank you !
FLEXnet Lincensing checkout error. Local checkout filter rejected request, Feature: REVSU_F_S
License path:
FLEXnet Licensing error: 73,125
For further information, refer to the FLEXnet Licensing documentaion, available at “www.flexerasoftware.com”
Read more
Hi there,
I don’t know why but for 2 day I cannot sing in to Lync. I have this error and I don’t know how to manage it. I have updated Lync to the latest version and also my PC is updated. Any solution ? My Internet connection is good so what could be the problem ?
Thanks !
Lync
Cannot sign in to Lync
There was a problem acquiring a personal certificate required to sign in. If the problem continues, please contact your support team.
Close
Read more
Hi there,
Call was not completed is my new error from a long list that I have. Most of them started to appear after I did an update for my Windows XP and I don’t have any solution for this. Can anyone help me please ? What should I do ? Should I reinstall Windows XP ?
Thanks !
Call was not completed or has ended.
When contacting your support team, reference error ID 52063 (source ID242)
Troubleshooting information is available online, including best practices for using Lync.
Lear More
Close
Read more
Hello there,
Licensing error is the error that I have since I made the updates of my Windows and I had to reinstall the Autodesk program. I can’t activate the program anymore because of this error. Can anyone help me with this ? What is happening ?
Thank you !
Autodesk Licensing Error
The combination of licensing being attempted is not supported.
Read more
