Archive
My problem has to do with the nRoute software.
Downloading the latest updates, I installed it and no error occurred during the installation process.
However, later the following error message popped up as I tried to run the program.
nRoute
There is a problem with the nRoute registry.
Please re-install the nRoute and start it again.
To solve the problem I re-installed the program a few times but without any result.
It would be great if you share your as I am at a loss right at the moment.
Please help me to get rid of the problem as I have no idea why it started in the first place. I tried to initiate my Palm Desktop and immediately “Failed to open Address Book Database” message popped up.
Not having any choice I had to exit clicking ‘Cancel’. I tried the ‘Hot Sync’ option. It didn’t work, and ‘Sync Expenses’ process continued throughout the day. I didn’t try it before and kept the option disabled in the past. How is it possible to fix the problem as the Address Book Database won’t open?
I have even uninstalled the program and...
Read moreI was installing Windows Vista Business Edition on my laptop. I had to do it via USB port as there is no DVD drive in my laptop. But when I clicked the ‘Activate Windows Link, a message popped up reading ‘The key is invalid for activation’. After that I was given a choice to change the key or purchase another one. As I tried later with the same key I used before the failure message appeared again reading ‘Error Code 0xc004e003’ (Please check the attachment for details).” Do I need to buy another key or I have some other...
Read moreI am trying to make a copy of a set of ‘One Foot in the Grave’ which I purchased. Using DVD Shrink application, I can copy those to an ISO file without facing any problem. But the attached error message pops up when I try to burn the files.
I did similar sort of job before and didn’t have any problem with that. Although the disks I am using don’t have scratches on them, I don’t know why it’s not working.
I need your advice concerning the facts.
I installed 12.0.2.026 patch, the latest version.
Now, I can upload my website and the speed of upload have decreased.
On top of this, the upload process stops just after 2 or 3 minutes without any reason.
It’s turning out to be very troublesome for me.
The picture attached shows how it happens.
Uploading files
There was an error opening remote file 7579.jpg for writing. (OpenRequest failed)
Retry Cancel
Read moreI am at a loss with the following message as it appears while I try to install an application in my PC.
“Error 1901: Error attempting to read for the source install database: C: WindowsInstaller213a4.msi”
My PC configuration is:
Windows XP SP1 Professional
Direct X 9.0a
ATI AIW 8500DV (Driver 6.14.0001.6255)
Pentium 4 2.4 GHz
1 GB SD RAM
80 WD HD
Why does the error occur? I can hardly cope up with the problem and I need a solution badly.
Every time I try to recover my disk the following error message appears.
Please come up with a solution for me as I want to avoid it by all means.
Error:
An error has occurred and it is not possible to continue execution The program will now terminate.
The error message was Thread fault Ident Thread Do you want to anonymously submit the error report?
Read moreDo you have any idea about the following error messages?
Please let me know if you know how to get rid of them.
Error:
The following files will be included in this error report:C:DOCUME~1SCOTTH~1LOCALS~1TempWER69da.dir00Mini010110-03.dmp C:DOCUME~1SCOTTH~1LOCALS~1TempWER69da.dir00sysdata.xml
Error signature
BCCode : 100000d1 BCP1 : 000000004 BCP2: 000000002 BCP3 : 000000000
BCP4 : F72E404B OSVer : 5_12600 SP : 3_0 Product : 256_1
Read moreFor the first time in my life, I failed to create a copy of a DVD. Going through the 14199 thread I tried to find out the following details for your convenience:
The Steps I followed for troubleshooting:
First I downloaded AnyDVD 6.6.1.3 Beta Version and installed the program. I tried it for my job. I tried CloneDVD 2.9.2.7 beforehand as I used to work with it in the past. After that I went through my drive information. RPC-2 drive region was set to unassigned. Going to device manager, I changed the configuration to Region 1 (Los Angeles, CA, USA). But...
Read moreI attempted to create a Diablo and received an error prompt. Since then, whenever I try to create any kind of game I receive an error report “Access to Diabdat.mpq denied.” The Diabdat.mpq is the file for Diablo. I have refreshed the program and the computer too and none of them has given the solution. There is still an error with the file. Any help will be appreciated.
Read more
