Archive
I have been using Windows Server 2008 R2 allowing users to log in utilizing Netvoyager thin clients through RDP by means of roaming profiles. As a file is deleted by a user, the file comes back again when the user logs back again.
The problem does not happen in the administrator account and any file deleted in it is permanently deleted and never comes back. It only happens in the normal user accounts. But if the user uses a thin client or usual pc connected through RDP, the problem occurs in both the accounts hence neither the user can delete...
Read more
I found a pop up stated “tasking.exe is trying to access the internet” as I was browsing the internet. I clicked on ‘Allow’ since I saw this program before, and instantly my IE9 stopped working (though IE9-64b, Firefox works). Hence now I am unable to stream media to my Xbox 360. All of my efforts on trying to fix it and going through the suggestions in here simply went in vain.
Please someone help.
I will be really grateful to you for your help.
Read more
We are having two computers one of which is a Desktop running on Win7 64-bit connected to internet access through LAN with the router and another one is a laptop running on Win7 32-bit connected to internet access through wireless with the router. The desktop can observe both the computers  on the network map as well as on the < Computer – Network> link. But the laptop can only observe the computers on the network map. It cannot see on the < Computer – Network> link, hence it is unable o access the desktop. Laptop can be pinged by...
Read more
I am using a Sony VAIO VGN NW 11S with Windows 7 Ultimate SP1 installed in it. I am unable to edit the visibility settings of it since I cannot find the options menu in it even though I have the Bluetooth software correctly installed.
I can see the icon in the taskbar but it can neither detect nor can be detected by other devices such as cell phones.
Please someone help me to sort out this problem.
Thank you.
Read more
Since I was having problems with RJ-45 Cable, I chose a different one to use, but the problems sustained. I can see a signal of yellow triangle consisting a black exclamatory sign in the taskbar as I plug it into my WildBlue modem and Lan input of my PC. I can find the red X symbol as always, on unplugging the cable from any one side. Although I have all the latest drivers of LAN for the board, a strange thing happens which is; the problem does not prolong as I reboot the PC. I got to see that...
Read more
My Windows XP 2003 Dark Edition has been corrupted recently due to a power failure experienced by my PC.  And, I was unsuccessful, as I tried to reinstall the Windows XP (Dark and Original both) later after the corruption.
Hence, I installed Windows 2000 service pack3 and attempted to install Win XP 2003 again, and I found an error message where I was asked to update the BIOS. Please someone help me by telling me the way to update my BIOS for Windows 2000 SP3. I will be thankful to you.
Read more
I am having Windows 2000 Pro SP4 and IE6 working great as always in an old PC of mine which I was supposed to give to one of my relatives. But suddenly, the IE6 stopped functioning. I could luckily find the problem which is, it joins a third forward slash to the URL like this:- www:///.
To make it work properly, I have downloaded the IE6 but it didn’t work. It only works if I manually type the URL correctly. In order to fix the problem, can anyone please help me by telling how can I edit the registry? The...
Read more
I am currently having Windows XP fully installed in the C-drive of my hard disk. To give a trial on Windows 8, I have downloaded a version of Windows 8 DP and successfully installed in the D-drive of the same hard disk of mine. As I installed Windows 8 DP, I was unable to boot into Windows XP hence using the repair mode, I could luckily boot into XP, but the same problem occurred for Win8 now.
Now I cannot boot into Win8. Please someone tell me how can I boot both the operating systems simultaneously using dual boot. I...
Read more
I am having some problems while attempting to install SQL Server on my Windows Server 2008 R2 standard. I have also gone through almost all the posts in here with no luck. These posts have not been useful to me although they might have been for others. As I follow the instructions written in the posts, the .net framework in redist folder is replaced by .net framework service pack1 which is downloaded from Microsoft’s website. Hence all of my trials went in vain. I will be really grateful if someone can help me to get out of this problem...
Read more
Recently after upgrading our Domino server to version 6.5.1, I have run into some errors. During installation I enabled the scheduling agent and had the admin as the signer of the code.
The problem is that the weekly scheduled agent is not functioning in accordance with the timing. When you configure it to run once a week it fails to do so yet when you configure it to run after a few hours let’s say two hours from that instant it will run. I would be glad to receive some help.
Read more
