Archive
I am facing problem in child domain with the set up of Exchange 2003. I don’t know why it is not allowing me to create exchange organization in the child domain. It appears as another server with the root server. Please help me to get out of this problem. I will thankful for all help and support.
Read moreHi guys! I have a problem with Hokuyo URG-04LX Laser RangeFinder or LIDAR. As I understand, this should work with LabVIEW. I installed the driver correctly according to the tutorial. But when running s program, I encountered errors. I don’t know if there is something wrong with the configurations. How can I configure LabVIEW with Hokuyo? I am running a sample program that is included in Hokuyo driver which can be found in NI Example Finder with LabVIEW Robotics. If I run the program, I got errors which I posted below. By the way, I’m using LabVIEW Robotics 2009...
Read moreI am using Windows 7 as OS and installed Windows Server 2003. When I am trying to connect to Windows Server 2003, it is not allowing to accessing any files or folders. But it is allowing to access from Windows XP computer with the same password and username. I don’t know why this is happening in Windows 7. Please help me to sort out this problem. Thanks in advance.
Read moreI am using Windows XP Professional. When I am using Lotus Notes 6.5 call tracking, an error is coming in red box and it says ‘lookup handle’. If anybody knows how to fix this, please inform me. Thanks for all the help.
Read moreI am using iMac Firefox 6 and the OS is Mac OSX Leopard. I have clicked on ‘No’ when the domino demands to install the necessary software for the proper working with ‘Firefox’. I thought it will install after some time because I am afraid about the data lose. But I cannot be able to install it. So, I can’t send mail from lotus ‘inotes’ in Firefox. If anybody knows how to install it manually, please let me know. I will thankful for all help and support.
Read moreWhen I open the ’.nsf’ file in the data folder it gives me an error message which says
Encrypted operation cannot support this version.
If anybody knows how to fix this problem, please let me know.
Read moreI don't know what happened to my laptop. It happened about 2 weeks ago, the problem is any of my software's are unable to connect to the internet except my anti virus and IE..
I have scanned my computer OS of time not only with antivirus but also with anti malware
Please man i need your help
Read moreI have downloaded 3.5 netframework for Windows XP in order to run a game. While installing, it gives me the error message that “you must install windows installer 3.1 prior to the installation of Microsoft.net framework 3.5”. So when installing the windows installer 3.1 the system again comes up with the message that “system have newer service pack, there is no need to install”. I am using the windows XP service pack 3. Should I need to install the newer version of windows installer or should I download the latest version of Microsoft.net framework?
Read moreI want to change the IPv4 tunnel to IPv6 tunnel. I have PC with windows 7 that is connected to IPv6 and my client and server is connected with IPv4.
I want to manage the traffic of client and server with IPv6 tunnel so I tried to set IPv4 interface in windows but it seems that routers do not support IPv4. Is there a possibility that I can configure my windows to support IPv4 to IPv6 tunnel because there is other way possible that one can configure from IPv6 to IPv4?
Read moreThe Linksys software in my Laptop is not connecting with my wireless router WRt54G and software gives the message of no internet connectivity. This happens when I re-installed the Vista home and tries to configure it but none of the router ports light up except some other lights. I checked the cables and unplugged it all and pressed reset button but it still router does not configure with my laptop.
Why my router is connecting with my Laptop? Is Vista not properly re-installed or are there any other configured settings in it?
Read more
