Archive
Hello.
I am using 8.5.2 via XenApp 6 on Windows XP and have this error from IBM Lotus Notes
IBM Lotus Notes
Failed to login
CLFRJ0010E: Notes initialization failed
On Windows 7 desktop rcplauncher.exe crashes as soon as an application is streamed.
Is there is any connection to the problem being discussed in the thread,
Are there any clues or solutions available?
Read more
Hello experts.
Our network is Lotus domino version 8. Our users make a connection to it using Lotus notes client.
For the need of some users who wished to use Outlook, recently we enabled POP3 access. Everything looks like fine except for sending emails to external domains.
You find attached a document below for error message.
I have made all the authentication settings available for Outlook but now I am thinking if there is still something to be enabled in Domino server.
OutIook Send/Receive Progress
0 of 1 Tasks have completed successfully
Dont show this dialog box...
Read more
Hello all!
Recently I bought a replacement computer (old one burned down... literally) and bought with win7 MS Office 2011 Pro including Outlook. I have to use Outlook for schedule and meeting purposes. But it does not work well as I expected. Outlook 2011 displays - 550 error
But the problem emerged only when I try to "reply" to or "forward" an email. I get the following error statement:
"The following recipient(s) cannot be reached:
(the addressee's email alias shown here on 24/03/2011 3:23 PM
Server error: '550 #5.1.0 Address rejected.'
Don’t found any in-correct after checked and rechecked the...
Read more
Hello guys,
When I am trying to install reQall for Outlook 1.2.0 and got the message that no supported version of Outlook is installed (Outlook 2010 beta 32/64 bit, Outlook 2007...etc)"
reQall for Outloook 1.2.0 SetupNo supported Outlook is installed
[Outlook 2010 (32/64 bit), 2007, 2003, 2002 0r 2000]!
But in my system there is Outlook 2010 beta installed and running. Why is it?
Thanks for suggestions.
Read more
Hi there, You guys!
I am facing this message when I try to install the SysAid Deployment Tool: "HTTP/1.1 401 Unauthorized". This error message popped up after entering the Account ID and Serial Key. I copied both from SysAid Info Page so, in my opinion, these should be correct.
Is there another way? Where I should look for those credentials? Please help me with this issue.
Thank you in advance!
Read more
Hi, everyone!
While trying to start up my computer this morning, I found the following message on a black screen. A logo at the top displayed www.ami.com then the following:
"Pri Slave Hard Disk: S.M.A.R.T. Status Bad, Backup & press F1 to resume".
I pressed F1 and the computer performed as normal. I was then flashed with the Windows error message requesting for backup. I checked the box that said do not show the message again and all appeared to run OK.
I visited the AMI site and found that it is trying to sell me storage! I have built this system a year ago. The specs...
Read more
Hello!
I recently installed Gallery3 with the theme roller module. I have downloaded a standard JQuery theme and attempted to upload it to my site. During the time of uploading, it suddenly closed with the following message: "Http Error" (image attached).Has anyone experienced this yet? Is there any way with which I can apply a JQuery theme without getting through the "Themeroller" module?
Thanks a lot in advance.
Read more
Hello all,
I am facing an issue with my blog. The front page of customwoods.co.za has the "Apologies, but no results were found for the requested archive. Perhaps searching will help find a related post." error message.
Why can’t I edit this page?
How can I get rid of this message and replace it with more useful things?
Thanks in advance.
Read more
I am trying to switch from Full Screen to Coherence mode but I got an error. "Unable to switch to Coherence. The virtual machine display configuration could not be applied. Please try again or contact Parallels Support ..." I am running OS X 10.6.5 and Parallels 6.0.11828. I hadn’t tried to switch to coherence mode for a long time but I was unable to. Please help.
Read more
Hi all,
I'm running Rubik for my administration theme. If a form is submitted without filling in a required field, say at /node/add/story, Drupal will provide an error message saying that the "Title field is required" and it will reload the form again with the required fields outlined in red.
The problem is that the error message and the form, along with the outlined fields, are not displayed in Rubik. They pop up in the default front-end theme. The form is viewed, like totally wiped-out, in the front-end theme. I need to solve this but I haven’t found any solution for this....
Read more
