Archive
i have a question that there is eject button in the context menu but i want to put insert button .Is it possible to do so?
Read more
I was wondering that if my antivirus is working or not.
If there is anyway to test it?
Read more
Do you know the difference between Multiplexing and Multiple Accessing?
Read more
How can I change the window output in the C programming provided that I wish to make the window full screen without using its properties and just through codes?
Read more
How can I fix a shortcut icon that is no longer linked to the correct file?
Read more
I have completed a setup of windows 7 in my computer. In my start menu bar the "Run" does not appear. Sometimes I need to remove unnecessary files via run. How can I find "run" in windows 7?
Read more
Please describe three data encryption technologies that have been set as industry standards for data being transmitted over a network?
Put in consideration that the data is being submitted to web sites over a network.
Read more
How to increase the bandwidth of the system which is limited so that i can browse more
Read more
how to hide partitions without using softwares of any kind.do anyone know here?
Read more
I was looking to clear the recent history every time my computer boots up.
How can i do that?
Read more
