Archive
I am trying to connect VNC via a live connection. I see an error message while looking at the remote machine directly.
The error message is shown below.
Thanks in advance.
Error:
VNC Server status and Troubleshooting
This page shows the current status of VNC Server and helps to
diagnose common configuration problems.
VNC Mirror Driver is not available [details]
Details
Address: 127.0.0.1 [copy | test | show all ]
URL: 127.0.0.1 [ copy ]
No users connected
VNC Server signature: e4-1f-84-10-f1-a8-64-1f [ what is this? ]
Read moreHi,
I am stuck in the process of installing a Vodafone Mobile Internet Dongle on Windows XP SP3 which I am running on my Sony Laptop. All my attempts always result in the same error again and again. Refer to the screen shot for the error message. I have also followed all the steps on http://ww1.out-of-warranty.com/?sub1=d69a2abc-f91f-11e7-a2a2-e8d590014d91 but still no help. Thanks.
Error:
Vodafone Mobile Connect Lite I…
Error 1720. There is a problem with this Windows Installer package. A script required for the install to complete could not be run. Contact you support personnel or package...
Read moreHello everyone, I have a LG super multi NAS which has a standard warranty with it. It comes with a Hitachi deckstar pair with 1TB of hard drive. I tried to install Microsoft Windows 7 on it, so I removed the previous drivers and formatted the hard drive.
It installed without any issue, but I somehow managed to format the drives using the Linux based file system. I managed to install windows 7 on it, but it’s doesn’t run correctly. I want to install the default firmware back on it. That is a Linux operating system, but when I tried...
Read moreHello,
I am having problems copying files from my Linux based ftp server to a windows based machine.
Whenever I try to access my ftp server from my LAN network it always gives me the following error:
Anyone have any ideas?
Error:
FTP Folder error
An error occurred copying the selected items from the FTP Server.
Details:
200 Switching to Binary mode.
227 Entering Passive Mode (10,1,1,1,40,75)
213 435847168
550 Failed to open file.
1. Hello guys, I need some help with Active Directory integration. Whenever I try this, I get this huge error saying:
GUI Server CTL Request Failed. Machine: hipnos01, Type: GUI_Server, Name: ; Code: 34
CTL Request Failed. Machine: hipnos01, Type: GAS, Name: ; Code: 34
CTL Request Failed. Machine: hipnos01, Type: BIM, Name: ; Code: 34.
Please tell me a way to integrate this and help me out.
Hello, any help would be greatly appreciated. I am using Cisco Supervisor Desktop, but I am having issues logging into the software.
I have a supervisor account type, but when I type in my user name and password, it gives me the following errors:
This ID does not have a Supervisor's rights. Then the application quits.
When I try to log in without a team login, it again gives me an error. I have attached an image with the error message.
Please help me out.
Hello guys,
I downloaded the Playbook simulator and tried to use it through a VMware player, but I get some errors and I can’t run the simulator. First, I have no .iso file in the downloaded folder to be attached with the VMware player and VMware gives me a following error:
Error:
Error while powering on :Cannot find a valid peer process to connect to.
Read moreHello, I am having problems installing the Adobe Flash Player 10 ActiveX plugin. I have Flash already installed on my computer. I have tried to uninstall it and reinstall the flash program through the active directory using the default installer.
I was having problems installing that, but that was solved when I bought the distribution license.
But now when I try to uninstall it, I get the following error:
Hello guys,
I want to install the Inventor Fusion English version. Everything installs fine, i. e installer successfully copies all the files required, but when the setup actually starts it says: “Failed to upgrade MSI runtime. Please reboot the machine”.
I have attached the screen shot of this error below. I have tried everything I know, but nothing helped. I have tried restarting my computer, I have tried re-installing, but every time I get the same message.
I am currently using inventor 2008. Maybe that is causing the problem, but I am not sure. Please help me as I want Fusion to...
Read moreHas anyone been in this situation? Please help! Today when I started my computer and tried to open AutoDesk Inventor, which I have been using for few months now, the strangest thing happened to me and it gives me an activation error and failed to start. I even tried to access my files through the vault, but the same error persists. One thing idea that I had was to clear or edit the registry for this application. So, I jumped into the regedit, but there is no registry value entry on the local computer registry for this application. Please...
Read more
