Archive
When I try to uninstall an AutoCAD based product, I find the following error message:
AutoCAD Map 3D 2011
Error 1402. Could not open key:
UNKNOWNComponents9A2A988C1F64E64D92A0801F4C780667D2F3875200990401020000060BECB6AB.
Verify that you have sufficient access to that key, or contact your support personnel.
Error 1402 during un-installation.
Need a solution.
Thanks a lot.
Read more
Hello guys,
I am using ADSL router for using Internet and I want to know how to portforward my router.Is there anyway to portforward it.Any help would be appreciated.
Read more
Hi all,
I am new to Wordpress, and I was looking to use some Wordpress plugins.
If you guys know which plugins to use  which would be best for me.
Any sort of help would be appreciated.
I want to build my first website using Wordpress.
Read more
How to install Odesk team application in a computer that uses Ubuntu operating System? Please help me out in this regard as I want to start working for Odesk ASAP.
Read more
What is the difference between intel core i3 and core i5 and which one is better? Take a case of  i5-661 which is a dual core processor with a clock speed of 3.33 Ghz and a  i3-560 which is also a dual core of 3.33Ghz yet a lot cheaper?
Read more
Has anyone tried out the new raspberry pi? I'm thinking of buying one and experimenting with it. What is the fedora remix like?
Read more
A friend wants to give me a microsoft office installer as a thank you gift. He's asking me whether I want a 32bit version or a 64 bit. how would I know which would work best for my computer? and what would happen if I got the wrong version?
Read more
I faced the following error message when I am trying to use certain workbooks:
Error -2147319765: Automation error
An element not found, Or an error like ' Sorry, your sheet cannot be used for this tool.
Error: ASAP Utilities – delete all objects on current worksheet
Sorry, your sheet somehow may not be used for this function. This could be due to macros with errors in your file. You may try it again by re-opening your workbook without enabling the macros in it. Other reason could be a bug in excel, for that case you can try to copy the information from your...
Read more
Which file systems support file and folder permissions and when you set the permissions on a folder.
What happens to the files and subfolders by default?
Read more
Hello experts,
I am trying to keep a file which I made for using Lab View but I faced a problem which showed the following error message.
"Error 116 occurred at Unflatten From String in Video MASTER Analyze VBI.vi->Lab VIEW API Off-Line CC.vi.
Also I found a possible reason message,
"A possible reason (s): Lab VIEW: Unflatten or byte stream read operation failed due to corruption, unexpected or truncated data."
I am totally new and really I haven’t any idea on how to solve it. However, I searched in some websites that undertake this trouble but still I couldn’t get any helpful article...
Read more
