Archive
Thanks for viewing my question:
What kind of OS do you guys suggest for me to use in order to set up my server. The server needs to have fast upload/download speed and good stability. Should I use an Unix based OS or a windows one, or is there some there a third option. Please state the pros and cons of the certain OS you suggest.
Read more
We all used Facebook and different types of apps related to Facebook and while using these apps we are asked to allow our basic information such as Inbox access profile information etc.
I am in doubt that is there any chance that intruders can get my Facebook information?
Read more
The instruction at 0x77c81f70 referenced memory at 0xecffffff.
The memory could not be read.
The message always appears every time i try to install a new operating system to my new Desktop.
I don't know if its the memory or the motherboard that causes the problem.
This happens everytime i install an operating system.
My Desktop is new.
Does anyone know the answer to my problem?
Looking forward for your help.
Read more
I have a problem with my printer. I can't access it through networking. I am using Windows 7 operating system.
Thank you in advance.
Read more
Every time i boot, the message "Bad_Pool_Header" appears even before the windows logo is completed.
The blue screen with the message Bad Pool Header appears every time I try to boot my Desktop.
I am Currently using Windows 7.
I tried reinstalling the operating system, but the same message appears after the installation.
The image below shows the error.
Read more
I wanted to ask about:
I have an integrated ATI radeon Xpress 200M GPU, and I'm able to play almost any game up to 2005-2006 release dates. Recently I have been thinking of over clocking it so I can possibly run even better games on it.
I have purchased a laptop cooler-desk, and I think I'm ready for over clocking.
Only problem is I'm not sure how to do it safely. Should I use a program in order to do so or over clock it using the BIOS.
Please provide me with a sufficient guide on how can I do this.
Read more
When I am trying access QOS for trimming the network and working with the Linux system to connect to the Cisco console. Every time I tried to open the QOS, I got an error related to the same application.
The error is as follows:
Links and More Information.
This error occurs when there is a problem reading the configuration file for the Web server or Web application. In some case the event logs may contain more information about what caused this error.
View more Information.
Read more
The CPU is running but no display is seen on the monitor. I tried to replace the hard disk and the memory but to no avail. I also tried installing a new power supply but just the same, the monitor only displays a black screen. Could somebody help me with my problem. I have tried fixing it for days but my desktop just wont work.
Read more
My question is:
How can I split my PC in order to use two sets of monitors, mice and keyboards from the same hardware. I've seen this being done at my school and they are using some sort of Hubs that branch out of the main housing of the computer.
They are using up to 4 hubs from each PC housing. And all hubs use different logons and essentially act as separate computers, they only share hardware.
Is this possible and if so how do I do it?
Read more
I am trying to connect the UART to connect to any named pipe or USB or serial adapter. I am trying this for my speech synthesizer. I am getting an error every time I tried to connect. The error “Cannot set the host port mode of the serial port 0 because the device path is empty or null.” I am getting the same error and cannot set the host pipe mode of serial port 0 as the path pipe seems to be empty. I have tried with every windows host but the error remains same.
Read more
