Archive
I just got a new laptop using Windows 7 Home Premium with 500 GB Hard drive. When I got the laptop there are 4 partitions in the HDD already. System which has 300 MB and HP Tools partition and HP Recovery Partition and the last the Windows Partition.
I want to create another partition so I don't have to back up my data elsewhere when I want to re-install the Windows 7. I've tried shrinking the partition and create new simple volume and after the last step there's an error 'There is no minimum size requirement'.
Then I tried partitioning using...
Read more
Hi
One of my desktop having a problem with the motherboards. I change the motherboard ( Gigabyte ) to a new one ( Jetway ) and then some problem showed up.
Everytime I plugged in a usb flashdisk or I put in a CD/DVD there's always an error message with title 'Windows - No Disk' and the details 'Exception Processing Message' I have to restart my computer then the message gone but it showed up again if I plugged the usb flashdisk back in or put the CD/DVD back in.
I have tried scanning for virus using different anti-virus such as Kaspersky...
Read more
Hi!
Several days ago I opened a link from the internet and my IDM ( Internet Download Manager ) showed up with confirmation to download a PDF file. I thought it's only a PDF file and what's the harm that could happen. After the download was finished I tried to open the file but it was taking a long time to open the file and in the end it failed and there was an error message 'The system has detected a problem with one or more installed IDE/SATA Hard disks. It is recommended that you restart the system'
Suddenly there's a pop...
Read more
I have some problems and hopefully you can shed some light on it.
I have tried to recover some deleted files and it was quite a lot of files and have different extension (.mdb, .accdb, .pptx, etc) unfortunately plenty of them are corrupted.
For image files, when I tried to double click via Picasa there's an error message 'Image Not Valid' and when I tried to open using Paint, the error message was 'Paint cannot read this file. This is not a valid bitmap file, or is not currently supported.' I have tried opening them using Photoshop, the error message was...
Read more
Hello!
I have a problem with my Yahoo Messenger. Whenever I chat, my nickname and everything that I write did not show up in the chat window.  Whenever someone tried to chat with me, there are no typing or writing being shown up in the chat window.
At first, I thought the colors of the font was accidentally set to white.  So, I went and checked it, but it's not the case apparently. I tried to remove Yahoo Messenger and reinstalled it, but still no such luck. I  tried to install the latest version, but the problem...
Read more
My computer keeps restarting. Windows will load as usual but when it reaches the log on screen, this error appears on my screen:
Isass. exe – System Error
Object name not found
Below is a button of OK which leads me to a series of start-ups every time I click it. In the first place, I never put any passwords on my account so it is unusual to go thru this log on screen upon starting. So I tried to boot on safe mode but my computer restarts before reaching the log on...
Read more
I am trying to run ipconfig command in XP operating system but only getting an error message “The request is not supported. Please contact Microsoft support services for further help. Additional information: Unable to query routing information.” I have done the same thing many times before.
I was looking for registry error, but no registry error was found. I have searched on different windows forum and also asked my friends to sort out this problem but so far all of them disappoint me. One of my friends told me to check up the firewall setting but I found it perfect....
Read more
As a part of maintenance work recently I have formatted my hard drive and reinstall the Windows Vista. I installed all the drivers and software as before. But I am having problem with the iTunes. When I try to run it indicates some registry errors and also saying that it could be a problem based on other CD burning software.
itunes setup assistant warning
iTunes Setup Assistant
Warning!
The registry settings users by the iTunes drivers for importing and burning CDs and DVDs are missing. This can happen as a result of installing other CD burning software. Please reinstall...
Read more
I have been running Microsoft office 2003 in my notebook and never saw this type of strange looking message.
When I try to open an office document a pop up message saying that windows installer is preparing to install the package.
I have to wait around a minute to open the file. I don’t understand what type of program required installing time and time again to run office program.
I thought it could be the result of corrupted system file and reinstall the office program. But same message does appear again.
What else can I do?
I am going mad...
Read more
I feel disgusted guys and need you help. I am running Windows XP service pack 3 in my Acer Aspire notebook.
Every time I start the windows a runtime error box appear and suggesting an error in internet explorer.
visual c++ runtime error in XP
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:Program FilesInternet Exploreriexplorer.exe
R6025
- pure virtual function call
I have tried to solve it by upgrading the internet explorer from IE6 to IE 7 but bad luck. I have also run a full computer scan by kaspersky antivirus, but no virus was found. But in the safe mode the...
Read more
