Archive
Hey guys,
A few days ago I have installed Microsoft Office 2010. On my computer I have Windows XP that worked fine with Microsoft office 2007. Today
I got error message when I wanted to open MS Word document. Did anyone had problem like this?
Thank you in advance Patricia
Windows – Out of Virtual Memory
Your system is low on virtual memory. To ensure that Windows runs properly, increase the size of your virtual memory paging file. For more information, see Help.
Read more
On my system I am using Windows XP SP 2.
My antivirus program found a few viruses that made some damages on my system.
Some files had to be deleted. Now I cant start search function. Should I reinstall windows?
If I do back up will it work when reinstallation is done?
Any suggestions?
Thank you Anthony
Error
A file that is required to run Search Companion cannot be found. You may need to run setup.
Read more
Hey,
On my computer I have installed Windows 7 professional and I got AMD 64 bit dual processor.
Before I used Windows XP. Because of it I got on my Windows  7 virtual PC, but I got error message.
Is there any suggestions to make virtualization enabled?
Thanks
Deborah
Windows Virtual PC
Windows Virtual PC cannot start because this computer does not support hardware-assisted virtualization.
What is hardware-assisted virtualization?
Read more
I am using my HP Pavilion M9400t with Windows Vista OS. The desktop is working fine. But after several minutes of starting, it got slower and just stop from working. I have navigated all around the screen using my mouse and keyboard but it still didn’t work and is not responding. I tried to open it again using safe mode with an active internet connection. It started up and worked but the internet has limited access only. I can’t visit different websites because of the limitation. Before that happened, I had a problem regarding my wireless card. You can...
Read more
I am planning to change my network settings because I am about to move into a new house with my roommates next week. I am using a laptop and a desktop with Windows 7 as their operating system. I decided to bring them into my new dorm so that I can access my important files coming from my laptop to my desktop. Moreover, I still wanted to have an access of the file manager from the network section of it located on the left panel. I thought that if I open my firewall I cannot have access from it....
Read more
I have my new iPhone 16GB and my MacBook. I wanted to transfer some photos from my MacBook into my iPhone 16GB using Bluetooth. I can do it easily using my old Nokia phone. But I don’t know how to do it with my new iPhone. How can I send files on my iPhone from my MacBook via Bluetooth? Or what other ways can you advise on transferring my files between my Apple devices? I need help. Thank you.
Read more
I bought a 32’’ flat screen television that I can use as my computer and television as well. I am really fund of buying such stuff which can be use in two other separate machines to make it more minimal in budget spending. I have been using my old 15’’ screen laptop for years so I can say this is a bit of enhancement regarding the size of the monitor as it gets bigger this time. I also bought a Bluetooth mouse and keyboard which I will use on my computer.  I have set up my bed six to...
Read more
Dear all,
On my Mac Book in my home network I got Brother All in one printer.
This is the first time that I am having this printer and this problem.
When I wanted to update firmware I got error message.
Can someone please help me with this problem?
Cheers
Charles
Brupdate Tool
Cannot find a machine to update
Read more
I’m trying to format my 150GB disk space in the disk management window but then I am encountering an error stating:  ‘’An unexpected error has occurred. Check the System Event Log for more information on the error. Close the Disk Management console, then restart Disk Management or restart the computer". After that, the drive that has 150GB space didn’t appear as same as the other drives as it was before. How does it happen unreasonably?
Read more
The entire songs I have in my files have a lot of duplicates from other album folders. I have own several compilation of album sets.  As I said, some songs were multiplied. And since the songs have duplicates, my computer is running out of space. I really want to delete those duplicates and have one copy of each song. Does anyone know how to track the duplicated songs so that I can delete it?  Can I possibly use shortcut like ‘pointer file’ whenever I see the duplicates of the songs? If so, how can I have this? I merely...
Read more
