Archive
I seem to be having problems with my laptop's mouse. Whenever I log on to my user account, the cursor starts blinking so rapidly that it slows down processes of the computer eventually freezing it. The cursor blinks so rapidly that it isn't visible anymore, so it's impossible to carry out simple tasks.
The main problem is that affects me is that, I can't copy or paste data. An example is, if I select a Ms Word document on my computer then try to move it to a flash disk, the paste function is disabled in the menu, which makes...
Read more
While connecting, TeamViewer is showing an error.
The error message is as below:
Teamviewer and the Internet connection on your partner's computer
Error
A connection could not be established.
A connection to the requested partner could not be established.
Please check TeamViewer and the Internet connection on your partner's computer.
I tried whole day but couldn't fix the problem.
Please help!
Read more
Explorer error in Windows 7. When I search I get this error. "Debug error! Program: C:Windowsexplorer.exe This application has requested the Runtime to terminate it in an unusual way."
Microsoft Visual C++ Debug Library
Debug Error!
Please contact the application's support team for more information.
(Press Retry to debug the application)
I am surprised to see even Windows 7 having such errors. I am just trying to search some files in drive D and get this error repeatedly and this closes all the Explorer windows and makes...
Read more
Windows update windows Vista errors.
Some updates were not installed-Failed 1 update.
It says "Some updates were not installed".
Failed 1 update.
Code C355 Windows update encountered an unknown error.
Try again and I repeatedly tried but does not succeed. I think its a important patch and was not successful updating it.
Any help is useful.
Read more
I am a new laptop user. I use the laptop to watch movies and gaming but since a few days my laptop monitor is giving me trouble. It shows a dark, zigzag picture. When I move the lid back and forth it seems to work fine but after some time, it goes back to the initial state. Is there any software(graphic) problem or it's a hardware problem? Can I fix it at home?
Read more
I am a little confused about the two processors manufactured by Intel and AMD. As per I have known before, this is one company before but time happened to break-up their team developer of the processor for a certain reason. Since then, I had to buy a lot of computers but now the quality and performance of the two differs.
What is the difference between the two processors?
Which one would be good in terms of usage in longer period of time?
I need to know the quality and performance of the Intel and AMD processor.
Any body who can give me a...
Read more
I am, computer coaching in a primary school. We don’t have many experts in here, so we often face unexpected problems from the PCs.
A few days ago a gentleman suggested to turn off the CD/DVD/USB auto run, he said that it would help prevent bad programs from auto running. Is it true?
If yes, then how do I turn it off? I am running Windows 7.
Read more
I just built my machine past few months and everything works fine. See my specs below pls.
Asus A8N-SLI
Athlon 64 x2 dual core 3800
Radeon x1800
1 GB RAM
Teac DW-224E DVD Drive
One day, I used the computer drive with disk on it, but it stopped from reading. So I checked out the drive in Computer but no worries because the icon is there, only if I opened it, the drive is empty. I tried to download new firmware and checked all the connections, but still the issue is there. I also...
Read more
I am using a dell laptop for a while (about 3 years). Has been in use, under a lot of pressure. Its becoming old I know, but I think my one is just overheating too much, since a few days. Is there any way I can fix it?
Read more
I have a laptop “Dell Vostro – 1500 “. I have used it for a couple of years. Recently some of the keys 'CTRL'/'ALT/shift is not working. I can’t figure out what’s wrong. It was working fine even yesterday. Do I need to change my laptop keyboard? Or is it just plain Windows problem? Please help.
Read more
