Archive
Hi my question is related to my monitor BenQ FP767, problem is that it won’t turn on when I press the power button to start it, the LED blinks like every 3 seconds and then no activity what so ever. Although sometimes the LED blinks and you can see the desktop just for a small portion of a second but that doesn’t happen very often.
The reason why I have not scraped it until now is that sometimes it just turns on fine and works for hours until I shut it off. I hope someone can give me...
How to fix a computer that won't turn on?
Thanks in advance for anyone answering.
Well I was hoping someone can tell me what is the safe temperature for over clocking a Pentium 4 1.8GHZ since I have an Old one at home which I want to over clock.
Also I have read posts which say that to over clock it you just need to mess with the FSB, so is this true or should I change something else as well.
My CPU runs around 48-55C these days, and I have to tell you I do have the option to lock agp and pci speed if that is of any help.
Read more
Hello everyone!
I am using a Windows 2003 and I want to connect the 3 computers to the server. I have the IP address, I configure already on the server as well as the 3 computers. When I tried connecting PC1 to the server, it doesn't work? Upon checking the manager properties of the computer, I noticed that the computer name set to Workgroup and it should've been in domain.
How can I change it to domain instead of workgroup?
Do I have to uninstall and install Windows 2003 again to be able to connect to...
I was wondering if you all can help me with something.
I'm using Microsoft Outlook 2007 with Windows XP 32 bit SP3. Is there any way to create a message that cannot be printed and cannot be edit by the recipients ?
A friend of mine said that it can be done by tinkering with the menu Tools -> Option but I have looked everywhere still didn't give results that I'm looking for. After a little bit 'interrogation', I find out that she was using Microsoft Outlook 2003. Can it be done in Microsoft Outlook 2007 as well ? I have some emails that...
Read moreHi,
I’m having a side by side error with BitDefender Antivirus Pro 2011 and BitDefender Internet Security 2011 with Windows 7 64 bits!
to be working.
This problem is indeed bothering me! It all started when I reformat the computer. On the first day, it works properly but on the second day when i turned on my computer it'll always restart and then it cannot even load the Windows Vista logo. Yes I am using Windows Vista Premium for my computer. But before that happened, i used to install a LAN game after reformatting the computer.
How does this happened? What would be the problem of the computer?
It's getting me worried i don't want my computer will be malfunction.
Post your answers.
Please thank you.
Read moreHello guys How you are doing,
Need help here am i have numbers of flash drive at home and every time i used them (one at a time) Autorun pop up on screen which i hated it. That's why it irritates me, my computer logs and it takes a minutes after it'll works on. I want that whenever i insert it, no more Autorun! Hehehe i just want my work fast and automatic.
How to disable Autorun?
Do i need to have a software to do that or just explore the system? Please i need an instruction on how to do that...
Read moreHello,
I have a laptop with Windows XP SP3 installed and I was using Microsoft Office 2003. Several weeks ago I upgrade the Microsoft Office 2003 to Microsoft Office 2007 but the problem is I'm using custom installation instead of default installation.
In the custom installation I only upgrade Outlook 2003 to Office 2007 and remove the old version but apparently I have misunderstood the installation process so I only remove the Outlook part while keep the old version of Word, Excel, Power Point and after installation I saw both links of Microsoft Office 2003 and Microsoft Office 2007 when I...
Read more
