Archive
Hi there,
I am new to HTML and CSS and what I want is to remove those underline below Anchor text whenever you hover your mouse.
I don't really want those lines below my link.
What's the simplest way to remove that?
Read moreWindow Mobile OS is a new wave in Mobile Operating Systems. What Kernel do Windows OS follow in Mobiles? Kernels are labeled at which layer of OS Architecture? Do they have micro kernel architecture or monolithic?
Read moreI encountered, this message when I updated MySQL Server 2005. I heard that it is better to update my table so I did it. After connecting to the SQL server 2005 instance via a DAC (dedicated administrator connections) this error appears. Any suggestions?
Microsoft SQL Server Management Studio
A connection was successfully established with the server, but then an error occurred during the login process. (Provider: TCP Provider, error: 0-An existing connection was forcibly closed by the remote host.) (Microsoft SQL Server , Error: 10054)
Read moreWhat software should I install for my Windows 7 and what antivirus that should I install?
Many thanks in advance.
Read moreI am a blog owner and I always got a problem about copyrights. Most of my post in my blog are being copied. I know there is a script that disables right click. Can someone tell where to find it or if you have it can you put it here?
Read moreI have a problem about my computer desktop hardware. When i turn on my computer it doesn't proceed to my windows. I am using windows 7. How can i fixed this problem?
Thanks!
Read moreI have two operating systems and I bought intex internal TV tuner card. I have installed in both operating system and also attached the TV cables to card.
The problem with first operating system is that it shows all channels but it's remote is not working. The problem with the second operating system is it’s remote is working but I cannot select INPUT as CABLE TV. When I try to select it I get this message:
InterVideo?WinDVR Application has encounter problem and needs to close. We are sorry for inconvenience.
Please anyone help me.
Read moreMy windows is windows XP, and any windows can work on any old software for older systems like windows 98
But in previous days error message say that I need windows 95 to be able to run the program so please anyone tell me what to do and how to stop this message.
Error message:
This program requires Windows 95.
Read moreI am having some difficulty with creating links to files in Lotus Notes. I am able to create the links, but when the source file is changed it is not reflected in Notes. I am testing using Lotus Notes mail, and have been able to highlight a section of a file (e.g. Word document), and paste it into Notes (using Paste Special/Create link), and if I open the Word document and make a change within the section I highlighted, the change will be reflected in Notes.
If I make a change elsewhere in the document, the change is not reflected....
Read more
