King Lopezs
30 points
Posted on - 10/20/2012
Hi Experts,
I received a system error while working with AX Retail Database Utility.
However, I created a store database and working smoothly before receiving this error message.
I reinstalled the program as per guideline of the message but no remedy.
Have you any idea for the issue?
Please help.
The program can’t start because mfc100u.dll is missing from your computer.
Try reinstalling the program to fix this problem.
Hello King,
If you have already tried installing the application but you got the same issue then it is possible that the problem is with the setup that you are using to install it. You will therefore need to try getting another application from the internet and then use it for installation.
Nicke
Hi there user:
Install Microsoft Visual C + + Redistributable dll which is needed for Visual Studio 2010 projects. Below are the versions for different operating system. I recommend that you install all of these versions into your unit that maybe needed for different programs.
Visual C + + 2005 Redistributable Package (X86) http://www.microsoft.com/en-us/download/details.aspx?id=3387
Visual C + + 2005 Redistributable Packager (X64) http://www.microsoft.com/en-us/download/details.aspx?id=29
Visual C + + 2008 Redistributable Package (X86) http://www.microsoft.com/en-us/download/details.aspx?id=2092
Thanks for your post.
Best regards,
