The PaperPort installer doesn’t respond.
The following error is encountering at the time of installation of MFL pro suit.
Have you ever face such a problem.
As per the message, I had restarted PC several times but the problem was not solved.
Please let me know the solution.
Error
Please restart your PC and then ensure all active applications are closed – Then reinstall MFL- Pro Suite
[IS001]
Thanks,
Augustine
