Microsoft Visual C++ Runtime Error
Techyv expert I have come here for an annoying problem about Microsoft visual C++ Runtime Library.
I am using this program since 15 days. But I am getting Runtime error from yesterday. I have uninstalled the program and re-installed it properly, but it did not work. I have also uninstalled my firewall, but it is still remained in same condition.
I don’t know what I should do. My laptop is Dell N5010 and operating system is windows & ultimate.
If you can solve my issue then I would be grateful to you.
Error:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:WINDOWSsystem32regsvr32.exe
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application's support team for more information.
Best Answer by Grammar
Answered By 0 points N/A #96247
I noticed where you've tried a number of things to try and repair the program except one. Have you done a cleanup, not necessarily a windows clean up but that also helps. I'm speaking about a check for malicious programs aka malware. As simple is this might sound malware can wreak havoc on your programs, and most go undetected simply because you'd assume having an antivirus is enough when it isn’t since most malware programs don’t show up any at all in virus scans.
One of the best malware removal software I could recommend to you would be Malware bytes:https://www.malwarebytes.com/premium/ the link provided points to the free version which are actually quite good, but there's also a paid version which works just as well.
Download revo uninstaller as well its better at removing remnants of programs from your system and could come in handy if malware bytes is unable to remove all the registry entries completely.
Let me know if this helps.
Answered By 0 points N/A #96246
Some times it happens that a dialog box like this comes and says that Microsoft Visual C++ Runtime Error.
Operating system of Microsoft Corporation has some built-in library function.
All software uses these library files when they execute.
If they did not found there necessary resource then this error occurs. In other word when some of this library function does not run properly this error happens. You need this software to solve this problem.
According to solve this problem you need to download named “routine error repair tool”.
Download this software and install it. It will find that error and also correct it instantly.
Answered By 0 points N/A #96248
This error message indicates that there is a missing file. In your case it is the manifest files. And your application on visual C loads the C runtime library without the manifest file. Manifest must be there in any running application missing it is a great thing. To solve this problem the file should be included the link below describes how to include it and to solve your existing problem I hope it helps you.
The way to fix this error is by rebuild the application with a manifest. As it is an internal process and by default is done Visual Studio automatically when building application starts. It includes this manifest into the resulting EXE or DLL file. But for building the application at the command line, use the mt.exe tool to add the manifest as a resource. Use resource ID 1 if building an EXE, 2 if building a DLL. For more information.
https://www.microsoft.com/en-us/download/details.aspx?id=55984
James,
Answered By 0 points N/A #96250
There is an application in your computer that unnecessarily invokes C++. You’ll have to remove it manually.
1.     Reboot your computer in Safe mode  and run it for some time
2.     Then reboot it again in Normal Mode.
3.     Sometimes this rebooting in Safe /Normal mode clears the bug.
4.     In case it doesn’t help remove all unnecessary startups.
5.     You can do it by using any clean up software like AVG Tune up etc.
6.     Or do it hard way by running “msconfig” from Start Menu.
7.     Then in Startup, uncheck all auto start software.
8.     It’ll prompt to restart, do so.
9.     It’ll solve the issue and if you want some program to autorun go to the same menu and select the same, if you can recognize it and leave unrecognized unchecked.
Answered By 0 points N/A #96251
Normally this happen as you install new office package. When there is a program conflicts with Mosdmn.exe and Mosearch.exe this error occurs. Mosdmn.exe and Mosearch.exe files are part of the ‘Support for fast searching’ in office xp. To solve this I recommend following steps.
Select ‘run’ on the start menu.
Then Type msconfig.exe, and click OK.
Next click Selective start up on the General tab.
Then   clear all check boxes except for MoSearch on the Startup tab.
Then click ok and click yes when you are asked permission to restart the machine.
If the error message still there, repeat the preceding steps.
Answered By 0 points N/A #96252
It is a common error. Some times it happens that a dialog box like this comes and says that Microsoft Visual C++ Runtime Error. Operating system of Microsoft Corporation has some built-in library function. All software uses these library files when they execute. If they did not found there necessary resource then this error occurs. In other word when some of this library function does not run properly this error happens. You need this software to solve this problem. Go to this link https://support.microsoft.com/en-us/help/822521/fix-runtime-errors-in-internet-explorer
According to solve this problem you need to download named “routine error repair tool”. Download this software and install it. It will find that error and also correct it instantly. There is so many other way to solve this problem.
Answered By 0 points N/A #96253
It happened because two Run-Time DLLs were referenced in my DLL by some reason! As soon as I looked
inside of my DLL I found two strings: 'msvcr80d.dll' and 'msvcr80.dll', and the 2nd one is the reason of that run-time problem.
In order to resolve the problem I added 'msvcrt.lib' to the list of ignored libraries for DEBUG-configuration:
[Configuration Properties] -> [Linker] -> [Input] -> 'Ignore Specific Library' – msvcrt.lib
Answered By 0 points N/A #96254
You should have followed the instruction that is given below:
Two programs Mosearch.exe and Mosdmn.exe which are included in the startup program sometimes conflict with another program run in the background that’s why this problem is caused.
a) Click start and find run and click it
b) Type  msconfig in the  run box
c) Then click the OK tab
d) On the startup tab, uncheck  all the box within it except only Mosearch
e) Then click ok, after that computer asked you to restart it , click yes.
f) If the error Is not gone , check the Process System.ini   and  process win.ini file box at msconfig tab.
Answered By 0 points N/A #96255
Mostly, this kind of error can be caused by two factors:
1. Runtime components of Visual C++ Libraries are missing.
The other one is:
2. Software problem.
If the issue is caused by problem # 1 then I may suggest you to reinstall the Runtime components of Visual C++ Libraries to resolve the problem.
Below is the site’s link wherein you can download the C++ 2008 Redistributable Package:
Microsoft Visual C++ 2008 Redistributable Package (x86)
And if the issue still persists after installing above package, well the issue should be a software problem though. Now if the problem still repeats, I suggest you take a clean boot check whether it is a software conflict issue or just a missing file during the installation, as you said you uninstall the program. If not, it is still recommended to address the problem with manufacturer support.
For your convenience you may try to Clean Boot by following the below process.
 To Clean Boot:
1. Click Start, type in the Search Bar "MSCONFIG" (without the quotations) and press "Enter" to start the System Configuration Utility.
2. Click the "Services" tab, check the "Hide All Microsoft Services" box and click "Disable All" (if it is not gray).
3. Click the "Startup" tab, click "Disable All" and click "OK".
4. Restart the computer and then test the issue.
Note that Clean Boot process is a troubleshooting step. If some programs have been disabled, we can re-enable them later. If you see the System Configuration Utility, check the box of “Don't show this message" and then click "OK".
Please do monitor the system in the Clean Boot environment. If the problem does not occur, it indicates that the problem is related to one application or service we have disabled. You may use the MSCONFIG tool again to re-enable the disabled item one by one to find out the culprit.
Hope this helps 🙂
Answered By 5 points N/A #96256
Hello Voldemort,
I have read your concern regarding Microsoft visual C++ Runtime Library. An error unexpectedly appeared when you tried to open the application and want this to be fixed. Is it right?
Your laptop brand and operating system has nothing to do about this issue. In order for you to correct this problem, kindly answer these questions carefully and follow the succeeding directions below.
Did you update the program before this happen? – Current update may not bring good to your computer. Downloads were not all safe because it may bring virus to your computer.
Did you install another program to your PC before it happened? – Unsecured program installation aggravates virus mobilization therefor creating chaos on your system.
Do you have software installed for antivirus? – If you do, kindly scan entire system for possible threats and if something’s found, remove it and heal then start backing-up your files and prepare for OS reinstallation. The system may have been corrupted by the virus.
I hope I am in the right track of understanding your concern and give you a hand to fix the problem. I hope this information is of good help.
Good Luck!
Mali
Answered By 0 points N/A #96257
Hey, you should try removing the program , and reinstalling it and restart your pc as you remove and re-install. But re-install the latest version as technology is updating everyday.
Hope this helps.
Answered By 0 points N/A #96258
Basically runtime error is a common error in the system; however here is some possible reason that may responsible for the run time error:
  • If there is no memory space or very little memory available for loading the program.
  • If there is a registry problem.
  • A virus or spyware may obstruct the program to run.
Any way to solve the error you got, just try the following steps:
  • From the start bar open run and type CMD and then press enter, type regsvr32MSVCR80.dll and press enter then reboot the machine.
  • If the windows defender is installed in your system then uninstall it and then restart the system again.
Answered By 0 points N/A #96260
Hi!
Runtime errors are software and hardware problems. It will occur if you are running two software programs that are not compatible with each other or a RAM (Random Access Memory) problem.
Since what you have is a newly installed software, try running the program alone with no their software's running. If still the same problem, try updating windows using "windows update".
Once windows is updated, restart the computer then try running the program again. If you re-installed your firewall back, please run a full system scan to check for any virus. Also, please check your RAM (Random Access Memory) if it has the minimum amount to run the program.
To fully understand on the issue, you can check the event viewer. You go to "windows log" then click "application". You will see there the error and the information of the error message. From there, act accordingly depending on the information given. If its a .NET issue, you need to go to the link to remove and reinstall .NET.
Answered By 0 points N/A #96261
You see there are 2 factors that causes this problem
1st: Runtime components of Visual C++ libraries are missing.
2nd: Software problem.
If the problem is caused by the 1st one, you should reinstall the runtime components of Visual C++ libraries to resolve the problem.
If the problem still persists after installing the above package, the problem should be the software itself. I suggest that you take a clean boot check whether it is a software conflict issue, and if not, it is still recommended to address the problem with the manufacturer’s support.
Here are some suggestions for clean boot check:
  1. Click start, type “MSCONFIG”(without the quotations) in the search bar and then press “ENTER” to start the system configuration utility.
  2. Click the “Services” tab, check the “Hide all Microsoft services” box and click “Disable all” (if it’s not gray).
  3. Click the “Startup” tab, click “Disable all” and click “OK”.
  4. Restart your computer and then test again.
Note: Clean Boot is a troubleshooting step. If some programs have been disabled, you can re-enable them later. If you see the system configuration utility, check the box of “Don’t show this message” and then click “OK”.
Kindly monitor the system in the Clean Boot environment. If the problem does not occur, it indicates that the problem is related to one application or service we have disabled. You may use the MSCONFIG tool again to re-enable the disabled item one by one to find out the culprit.
Answered By 5 points N/A #96263
The error is from a non registered DLL extension that is needed by your code to run properly. to fix this make sure you have installed all the needed softwares your code have. crystal reports, mysql or whatever your software is accessing for it to run.
regsrv32 is a registry application that executes calls from a given code to outside files.
I hope this helps
thank you
Answered By 5 points N/A #96264
This is common error and can be resolved by taking below steps:
Click Start, and then click on Run.
Type msconfig.exe, and then click OK.
On the General tab, click on Selective startup.
On the Startup tab, click to clear all check boxes except for MoSearch.
Click OK, and press yes to restart the system
This will resolve the issue.
Answered By 0 points N/A #96265
R6034 runtime error occurs when using some of the internet browsers including firefox on windows operating system. This error could appear when loading the windows or use of some programs which require C runtime library.
To overcome the problem, continue to do any of the following steps.
1. Start in Safe Mode to filter the errors.
To do this, restart your computer and select F8 functional key to log on to the same mode. Complete the tasks and reboot the system to go back to the normal mode.
2. Clean Boot stops the services that are unessential to the computers.
To perform this, click Start > type “msconfig” in the search box and press enter. click continue after accessing the User Account Control permission. Then on the General tab, click Selective Startup->Load Startup items check box. Now, click the Services tab, click Hide All Microsoft Services check box, and then click Disable All and press ok. Now, restart the computer and check whether the issue has been resolved.
3. Clean Out Viruses
Viruses are a huge cause of the r6034 error because of the installation of other corrupted software’s which will infect the computers. It also blocks access to the Internet, which can cause the 10061 error. To fix this problem, you have install an antivirus program “XoftSpy“  , the best software to overcome this type of errors.
4. Clean Out the Registry
Another big cause of Runtime errors is “registry” of your system. The registry is a large database which stores files and settings that your PC requires to run and it is becoming corrupted with many errors. To fix this problem, you should use a registry cleaner to scan through the part of computers and repair any of the damaged settings that are inside it. “Regace” is the one which suits to resolve this kind of errors.
Hope the above information helps you better.
Answered By 10 points N/A #96266
Dear Voldemort
Corrupted files in the windows registry database are the main cause for the run time errors, yet it could also be caused by un-updated software or a bad installation.
This error can appear after you load windows or after you use a program that needs a C runtime library such as Visual Basic, and when the application can’t run the C runtime library you get this error.
To fix this error you need good anti-virus software to scan your computer, windows registry clearing software to scan your windows registry for any errors.
Now you have to restart your computer but in the safe mode by pressing the key F8 until you see the option start with safe mode, chose it and you’re your computer will start in safe mode.
The safe mode opens only drivers that windows needs in order to start, so it doesn’t open all the programs that usually open with a normal mode start, that is why it is very good for troubleshooting programs that doesn’t work properly
Open your anti-virus program and search for updates before your do your scan, once update is finished start your scan and fix all errors, now open your registry cleaning software and let it scan also
After you finish all your scanning and fixing all problems found reboot your computer and starts normally without the safe mode.
Let me know if your problem is solved.
Answered By 5 points N/A #96267
Hi
Just rebuild your application with manifest. Building an application with Visual Studio automatically puts the manifest into the resulting EXE or DLL file.
If you are building at the command line, then use the mt.exe tool to add the manifest as a resource.
You can use resource ID 1 if building an EXE, 2 if building a DLL.
More Info visit here
Another Solution is to repair your system registry.
It can be done by downloading perfect optimizer. Install this error repair tool and fix all registry problem.
Hope this will help you.
