KMail encountered a fatal error
Hello Everyone,
After I do some improvement on KDE 4.6 to Alien Bob's KDE 4.7 packages in Keisty fawn and re-configure KMail version 1.9.6 setting then tried launched KMail but it fails to start receiving an error message. Is there other information to configure my KMail to start properly? Please give some ideas to prevent this kind of error. Thanks in advance!
Error KMail:
plasma-desktopee2398
Error:
KMail encountered a fatal error and will terminate now.  The error was: Failed to fetch the resource collection.
Answered By 75 points N/A #117219
Hello Rainner,
The fatal error you are receiving while executing KMail could be as a result of wrong settings that you have set. Maybe during the improvement process that you did by changing KDE to alien bob and the configuration of the mail, there must some settings that you might have missed to configure, or you configured them wrongly and thus resulting to the problem that you are having right now.
You should therefore review the settings and the modifications that you did, if there is something that you did not do right then you will need to change it.
Hope this helps.
__
Regards
Lee Hung
