How to remove the registry for a software?
Actually, I installed a software of a trial version with have 30 days validity.
After passing a month, it shows SOFTWARE HAS BEEN EXPIRED.
So, I found from a web source, says Remove the registry file from the windows and then re-install from initial.
So, now can anyone tell me how to remove the registry file of the particular file and where does it locate?
