Archive
Yesterday, when I opened the ‘far cry 5’ game, it gave a message ‘1058 error_serice_disabled.’ How to solve this problem and play the game without any problem?
Read more
While connecting and transferring data from iTunes, my device shows the error 0xe800002d. What are the causes, and the ways I can fix this?
Read more
I own an HP printer, and when I send a document to print then it gives an error 0xc19a0013. What is the meaning and what is the solution?
Read more
I was running my system when suddenly the power went off. When it came back I restarted it, and it showed the error 0x800240021 after the welcome screen, and also when I try to open any other programs, a lot of other similar errors are displayed. What should I do?
Read more
I am getting the error 0x8024001a when I try to update windows. What is the solution to this?
Read more
I am getting this 0x8007064a error. How to resolve it? What are the steps, I can use to remove it?
Read more
I am getting this error code 0x80042109 when I am using the outlook service to send emails. Can anyone tell me how to solve this error?
Read more
In Windows 10, when I try to copy libraries, I get an error code 0x80028ca0: Type Mismatch. How to rectify the error? Can anyone help?
Read more
What is werconcpl.dll, and what are DLL files? How can I install werconcpl.dll? What are the primary reasons to get DLL-files.com clients?
Read more
How to compile forms using admin in r12 and what is the task which is to be performed before running admin? What are all options available on the main admin menu?
Read more
