Archive
A common issue as reported by a number of android users especially of some users of HTC that no pop up appears when the power button is held down so we cannot choose whether to go for a hot boot or a simple shut down. How can we work around this issue?
Read more
This is a common issue with Joomla 1.6 and later versions that users fail to log in to their own website after they have decided to host their site from a different location. What is to done to get access back?
Read more
Often working on multitenant systems as a user we face the problem of overridden htaaccess or disabled htaaccess, thus all directives in htaaccess are ignored and if we face some configuration issue we cannot modify the access for that specific file or directory. How to work around this problem (provided you have certain level of system access)?
Read more
Often users report that when they try to send a file more than 4 GB to a flash drive it shows that not enough space is there for the file but when the users checks the availability of space in the flash drive there is more than enough. How to work around this problem?
Read more
Running Ubuntu on low physical memory can be hassle, in this case while loading Ubuntu starts using swap partitions that is hard disk to get enough memory requirement at a time this greatly reduces system speed. How can we work around this issue?
Read more
Though Ubuntu 12.04 comes with a stable GNU of Linux it has been reported of a number of issues on of the most frequent of which is being Ubuntu failing to restart by normal restart procedure. How can we solve this issue?
Read more
Often Ubuntu users constantly keep getting a report that shows system program problem detected and it keeps popping up even if you have solved all issues. How to stop this report from constantly popping up?
Read more
Often users of windows 7 report that their hard disk is filling up with junk that they do not know about. Even after repeated scans no malware has been found. How can we solve this issue?
Read more
Often our android phones get so much cluttered that we have no option but to format the phone. How can we format an android phone from our pc with minimum hassle?
Read more
When we are working on multitenant Linux based systems that shares the same hardware resource with a number of users we need shells that can run on just one instance on every single computer connected. How can we temporarily achieve that if we are not ready for complicated automation?
Read more
