Archive
Hello Pals,
I have been unsuccessfully trying to uninstall Adobe Flash Builder 4 from my Mac machine for two days now. Whenever I try to uninstall using the ‘Uninstall’ option from the Adobe Installer, it launches but soon afterwards, I get an ‘uninstallation encountered errors’ message. I tried restarting my machine and uninstalling several times and did not make any progress with removing the software. Then I gave a try at removing the software as one usually does on a Mac machine. I dragged it into trash and then emptied trash. This I imagined had fixed the issue and proceeded...
Read moreI have an Evernote Version 5 and I am encountering an error on running it. The error says, "Evernote Version 5 has encountered a problem and needs to close." And I can no longer use Evernote. I tried to uninstall and re-installed it back to no avail. How can I be able to resolve this issue? Please help.
Read more
Hi Experts,
When attempting to install the new NovaBACKUP 12.2, I keep getting the following error message that says there is a problem with this Windows Installer package. I have NovaBACKUP 12.1 installed in my system without any issues. So I customized my install to include only NovaBACKUP local devices. The installation begins and a little while into the installation, I face the error message shown in the attachment. And I find that this partial installation has removed my 12.1 version of NOVABACKUP. So I finally ended up installing NovaBACKUP 12.1 again. And thankfully, this went smoothly without a glitch....
Read more
Hello Pals,
I completed installing Topo USA 7.0, without any errors or warnings on my machine and then eagerly attempted to try out this software when I got this disappointing error message ‘Topo7 cannot be started because your Windows access rights are not compatible with the program. For more information contact your System Administrator.’ I understand that the fix for this issue is to run the software as administrator. Unfortunately, we are logged into a domain and cannot afford to give administrator access to individual users on the domain. Is there any way to run the software as administrator in...
Read more
Hello Experts,
I have been using Sibelius 5 without any issues for some time now and recently upgraded to Sibelius 6. Everything was fine with this version too until yesterday. From yesterday, when I try to initialize the playback devices from Sibelius 6 the following error messages turn up: ‘Audio engine Error: bad settings.’ I can’t think of any new changes I have made to my system in the last few days. No new installations or updates. I can click on the OK button on the error message and get back into Sibelius but I find that I am not...
Read more
I am trying to install an AIR app published from Flash on my laptop having Flash Professional CS6 and I receive an error that says the installer has been misconfigured. However, I was able to install this app using the same installer on a desktop. I tried to solve this problem by searching for the APP name in ‘AIR settings’ dialog and on not finding the name there, I assumed it to be completely uninstalled and proceeded with a new installation of the app. However, this did not work for me. Then what is causing the issue? My Flash...
Read more
Hello All,
I recently discovered that Photoshop CS6 hates repeating transformations. Here is one issue that has been bugging me. Please take a look. I can transform a 400 MB Smart Object using without any issues. Then I try to repeat this transformation on another target by choosing ‘Again’ from ‘Transform’. And this time, Photoshop gives me a warning that says the result would be too big and due to this the transform cannot be completed. I tried for a second time as follows: I make a brush stroke in new layer of a new file. Then I converted the...
Read moreHi Experts,
I am very much crazy about Office, I do lot of works in that. So when I try to install LibreOffice 4.0.2.2, it went well to some extent and got an wired message before it finishing. I am the only one user, no sharing and not in network. Previously I have installed many small applications in my system everything is working well. I have privileges to access my system. Experts suggest me some solution.
Error Image
Words in the Error Image
LibreOffice 4.0.2.2 Installation Wizard
Error 1303.The installer has insufficient privileges to access this directory: C:Program Files(x86)LibreOffice 4.0program....
Read moreHi whiz,
I was playing this game draw something for a while with this error, but all of a sudden it stopped running. I used to play in IPad and phones. I try by deleting it and installing again, nothing worked. By the way it is working in IPad not in android phone. Friends help me to solve the problem.
Error (Marmalade v6.2.1 [336699])
Architecture ARM5TE used by application not compatible with this device’s architecture(ARM5T). This application is likely to crash.
Read moreHello All,
I was trying to install MicroStation V8i when I had to drop it because of a ’could not open key’ error message. I tried installing a couple of times and every time I get this error. I am the only user on this computer and I have full administrative permissions. What then, is meant by having sufficient access to the key to open it? I attempted to fix this issue by browsing to the erring key from RegEdit and giving it full control permissions. When I try to install Microstation again, I learn that this solution did not...
Read more
