Archive
Hi Tech Pro,
When I try to start the Pro Tools LE version 8, I got this error message. I tried with different drivers’ installation from the website, nothing worked. I googled, figured some solutions and tried some. I checked whether the interface is directly connected to the port and also tried to connect it to a different port. Someone could help me to solve this error? Thanks for your help.
Error:
Unable to locate Digidesign Hardware. Make sure your hardware is connected and turned on. Click “OK” when the hardware is ready.
Read moreHey,
I am able to connect to the server without any issues. For some reason I am getting this error after executing some commands. Has anyone experienced this before? For your information I have windows 98 operating system 64 bit and 1 GB RAM. What is causing this error? Please help me. Your help is great.
Error :
There was an error while attempting to show the File Save dialog.
Error was [-2147417848]: Automation error
The object invoked has disconnected from its clients.
QwikQuote will now show an alternate Save dialog so you don’t lose your work.
Read moreHi friends,
I formatted my hard disk and started from the scratch like installing all the software again and setting up the drivers. The problem appeared when I about to start the Easy Photo print, the error message pops up. So then I tried by again by re-installing the latest version of easy Print module. I thought the system is asking for update, but it is not working even after latest version update. What I have to do now to correct this error message. Help please.
Error:
Epson Easy Photo Print
Restart Epson Easy Photo Print after installing the...
Read moreI recently installed HD PVR 2 on my Windows 8.1. Whenever I launched it, an error was appearing and I cannot start the software. My Windows was on my SSD if this is the reason why the error appears. How can I fix this?
Error starting device
The application was unable to start the device. Reason given:
Try closing the application, disconnect the device, wait a few seconds, reconnect the device and wait for few more seconds, then restart the application and try again. If the problem persists, contact support.
Read moreHi Everyone,
I am facing an issue with downloading online templates or Clip Art on to a Mac machine running OS X 10.8.5 and Print Master 2012 Platinum. I checked the internet connection on this machine and verified that I am connected to internet and do not have issues with the connection speed. I am able browse the web and I could download a PDF. But when it comes to clip arts and templates, I get this error. No matter from which ever site I try, or how often I try, I always get this error. What should I do?...
Read moreI have posted some shockwave movies online. It played well before but now it is sending me an error stating:
Shockwave Error
This Shockwave movie has error that have caused playback problems. Please contact the author of this content regarding this problem.
Shockwave is unable to continue.
The problem will start when accessing the shockwave movie for few hours then if I waited and visit the site again, the error is gone and the movie will load without issues. However, next time I visit again, the error is once again existed. How can I fix it?
Read moreQuestions:
I have ArtRage Studio Pro 3.5 installed on my laptop and all of a sudden I started having trouble opening the .ptg files. I was doing a drawing when ArtRage crashed and I was able to reopen the file and only had to redo some parts and saved the file. Again I had a crash and this time when I try opening the file, I get this error message shown in the below attachment. And there is absolutely nothing on the canvas. There were no color samples, layers or references present. I tried exporting the file, but this file...
Read moreAn error occurred when trying to activate my Windows 8.1. I searched for a solution online and found out that the error code given in the error message means there is a mismatch in the SKU. How can I activate Windows 8.1? Please help.
Windows Activation
An error has occurred
You can also contact Microsoft by phone to help resolve this problem.
Code:
0xC004F069
Description:
The Software Licencing Service reported that the product SKU is not found.
Read more
Hello All,
I run into this error message while trying to install PrintShop 22 into my laptop using windows 7, 64 bit version. The program compatibility assistant informs me that the application requires .NET Framework 1.1 to install. Following this direction, I had the .NET framework installed on my system. Then I attempted installing the program again. But even now I get a message reporting compatibility issues between windows 7, 64 bit and Printshop 22. Now I am confused, was it only this .NET framework that is missing or am I wasting my time attempting to install incompatible software on...
Read more
Hey,
When I upgrade my connectify to latest version I get this error often. As per the error message, I tried to un-install the previous version and I try to reboot the new one. It is acting a loop, again and again I am getting this same error. How to get rid of this loop error? Help me to fix this error, makes me frustrated.
Your help is great.
Error message:
Connectify Setup
A previous run of the Connectify installer requested a reboot to complete. Please reboot your computer before running the installer.
Read more
