Archive
Hi Pro,
The download for Microsoft Office package went pretty well and good. Then I started to install the package in the computer, I have windows 98 64 bit operating system. While setup I stuck up with an error, I don’t understand the error message it explains the error in German language. I think it says something about 32 and 64 bit. How to fix this error? This is not compatible with the system. Please help.
Error Title:
HOW TO: FIX ERROR - "the 'microsoft.ace.oledb.12.0' provider is not registered on the local machine"
Errors:
I installed Office 2010 64 Bit...
Read moreI am attempting to activate ATI/AMD driver via the Hardware Drivers app with Jaunty. This is just upgraded with a clean Intrepid install. I saw the status saying the process is downloading but there is nothing that appears and it seems like it's not working even though the System monitor is stating that it was downloading. When I opened it, an error appears. Please tell me what to do with it. Thanks.
Sorry, the jockey backend crashed. Please file a bug at:
Ubuntu-bug jockey-common
Trying to recover by restarting backend.
Close
Read moreHi,
When I try to open a PXD of my image with The Pixlr Grabber I have this error message. I can open the image properly but I cannot edit it because of this image. I never had this error before so I am stuck on it. Can anyone help me to fix this ? Is there any error when I saved the PXD file ?
Thank you !
An error has occurred, please try later! Error: Error #2058
Read moreHi all,
When I am trying to update the Android versions in the computer I am getting this error message ‘SDK Manager: failed to install’ the concerned folder is not in use by another program or application. After the error I even deactivated the Anti-Virus software. But still the error remains the same. Please help me to sort the error. Thanks.
SDK Manager failed to install
-= Warning!
A folder failed to be renamed or moved. On Windows this typically means that a program is using that folder (for example Windows Explorer or your anti-virus software.)
Please momentarily deactivate your...
Read moreHello trouble shooters,
I had a severe virus attack in the computer, most of the application is not working properly and the important thing browser is also not working too. I decided to try factory restore in the system, but it did not complete successfully. I got an error message saying antivirus is running on the computer. But it is not running I disabled it before starting the system restore. Please help me to fix the error. Thanks.
System Restore did not complete successfully. Your computers system files and settings were not changed.
Details:
System Restore could not access...
Read moreHi Friends,
I have been enjoying the Power Pivot with Office 2010 beta for a month. But today morning I got this error message as soon as I started the Office, surprised. I have some work to do with it. Immediately I followed the instruction in the error message. I uninstalled the current beta version and I installed the recent version. I am getting this same error again, am I going wrong anywhere? Please help. Thanks in advance.
PowerPivot for Excel
Your beta software has expired. Use Add or Remove Programs in Control Panel to remove the beta...
Read moreHi there,
When I want to paste a new selection on a new window on Paint.Net I have this error message. If I try to paste the selection on the same window from where it was cut it works fine. I never experienced this error before and is something new for me. Can anyone help me to fix this ? Why I have this error on a new window when I try to paste or insert something ?
Thank you !
There was an error copying the image to the clipboard.
Read moreHello Pro,
When I am using SQL 2008 Repot Builder to report on SharePoint lists I ended up with an error message. When I am setting up the credentials to use the current windows user I stuck up there. I verified the connection it is working well. Am I going wrong anywhere? How to fix the error? Help please. Your help is great.
Microsoft SQL Server Report Builder
Unable to connect to the data source. Please verify the connection properties and credentials.
OK
Details
Read moreHi expert friends,
I am not technical person; I don’t have much knowledge about the TARDIS Console. While working I ended up with an error message and it closed. I don’t understand anything from the error message. So I attached the image please do explain me. Really I need help. Your help is appreciated.
TARDIS console has encountered an error and needs to close Do you wish to send an error report? Send Report Cancel
Read moreHello Pro,
When I am working with Microsoft Access, a window popped up with an error message. I was trying to create a database, all of sudden I got this error message. Still I am able to continue with the database. What might have caused this issue? Please help me to fix the problem. Thanks.
Microsoft Access
An error has occurred.
TECHNICAL DETAILS
Correlation ID: 690afc9b-4032-c037-17c0-a6c36b9f47fc
Date and Time: 2/5/2013 11:4842 PM
OK
Read more
