Archive
Hello folks,
The System setup went good without any problem. I have Windows 98 64 bit operating system. The problem triggered when I try to set up an account in the Outlook. The connection to Microsoft Exchange is unavailable, but the outlook is connected to the internet. Someone could help me to solve this error. Thanks for your help.
Microsoft Outlook
The action cannot be completed. The connection to Microsoft Exchange is unavailable. Outlook must be online or connected to complete this action.
OK
Read more
When I am in the process of updating the Panda Antivirus Pro 2010 to the latest version I got this error message. I don’t understand the error message, so I blindly reinstalled the update again. But no result, How to fix this error? I am frustrated because of this error. Please help me to get rid of this error. Thank you.
XML Parsing error
XML Parsing error inside file ‘C:Program Files (x86)Panda SecuntyPanda Antivrus Pro 2010Hotfixfixcatalog.xmI.
Warning: Unmatched end tag
At line 65, column 78.
OK
Read more
Hello friends,
I get this error message when I try to restore the iPhone using iTunes. Last month I did this without any problem. But now this error message appeared in front of me. Is this a problem with the version? Do I need to update the version to latest one? Please help me correct the error. Thanks.
iTunes
The Phone iPhone could not be read. An unknown error occurred(3194).
OK
Read more
I am working with the .veg on Vegas Pro 10 and I'm not sure why am I getting a streaming error. It seems to be related to Sony Media Manager but I am also uncertain which file the error is showing. Can someone explain the process on resolving the issue? Thanks a lot!
Vegas Pro 10.0
An error occurred while creating a proxy file for a stream.
The file could not be created.
OK
Read more
Opening Vegas Pro 11 results with an error. It says, "The Microsoft .NET runtime could not be initialized." And clicking on the OK button on the error message results to the error below. I already tried to uninstalled and re-installed Vegas Pro including the Microsoft.NET. I don't know what else to do to fix this. Can someone help?
Vegas Pro
An error occurred starting Vegas Pro.
A necessary COM interface was not available. You may need to reboot your computer.
OK
Read more
I am setting up Open Directory (OD) Replica through the Server.app with Mountain Lion 10.8.2. However, an error below appears when trying to create a replica. The DNS is properly configured and I also run the command "sudo changeip -checkhostname" and the result is a success. But why am I getting the below error? Please send me some help.
Confirm Settings
An error occurred while configuring od as a directory replica. Please check your network configuration and try again.
Back     Close
Read more
Hello Pro,
In the windows 8 64 bit operating system I have Microsoft Dynamics GP 2013 Web Management Console. I am facing this error for a while in the computer. I am not able to figure out the exact reason for this error. What need to be activated in HTTP? Please help me to find the root cause? Thanks in advance.
Unable to access SnapIn config data store. Home Snapln will not be loaded.
Ok
Read more
I am running Windows 8 Pro x64 and I am having an error on Workstation installation. I installed Workstation previous version before without issues but right now, I have this error on version 9.0.1. Right after the installation, the application hangs and it doesn't work for at least an hour so I decided to forced kill the process. And the error appears:
VMware-workstation-full-9.0.1-894247
The MSI 'C:UsersJorisAppDataLocalTempvmware_1352395605vmwareworkstation_x64.msi' failed.
OK
Read more
A unhandled exception is showing on Microsoft Visual Studio 2012. This doesn't appear in 2010 version. I already tried to run a repair and delete the settings on Visual Studio 2012 folder. I even uninstalled and reinstalled and reset all settings. But none works so far. What can I do to fix this?
Microsoft Visual Studio Express 2012 for Windows Desktop
An unhandled exception of type 'System.Exception' occurred in test3.exe
Break      Continue     Ignore
Read more
I can't seem to make the masking tests work to be able to check on the CPU checking code so not to use the whole test equipment when needed. I tried masking vendor but when I tried to run on the Workstation 9 and Fushion 5, an error always appear and I'm not sure how to fix it. The error is enclosed below. I tried masking from Intel to AMD.
Cpuid - VMware Workstation
Feature 'cpuid.AMD' was absent, but must be present.
Module FeatureCompatLate power on failed.
Failed to start the virtual machine.
OK
Read more
