Archive
Hi friends,
When I try to install the EasyBCD in the computer, I ended up with an error message. The error message states that ‘The application failed to initialize properly. Click on OK to terminate the application’ I do not understand where I went wrong in the process. I searched for solution in the web, but no luck. I already have Microsoft .NET framework in the computer. Please help me to resolve this error. Thanks a lot.
EasyBCD.exe- Application Error
The application failed to initiaze properly (0xc0000 135). Click on OK to termriate the apphcation.
OK
Read moreI just purchased Replay Music and installed it on my PC. It works fine on the first time but after that, I started getting issues. I did not change anything on the settings. I decided to re-install the program then it works again after few recordings. On the last recording, I've got the same issue again. How can I fix this? I enclosed the error message I received.
Replay Music Error
Unable to contact music identification server for tagging. Please make sure you are online, your proxy setting...
Read moreHello. I have been trying to burn a file on my DVD writer, and I am keep getting an error. This error occurs to me for every DVD I try to burn. I really need to write this file on DVD, it is very urgent. I use windows 7 home premium. The image below shows my error. If anyone knows the solution, I will be very grateful.
Waiting for help.
I/O Error!
Device: [5:1:0] HL-DT-ST DVDRAM GSA-H12N UL01 (G:) (ATA)
ScsiStatus: 0x02 Interpretation: Check Condition
CDB:2A 00 00 05 CA 40 00 00 20 00 Interpretation: Write (10) – Sectors:...
Read moreWhen opening the Replay Media Catcher and record something, a pop up message will appear. It started after attempting to upgrade it. I already tried to uninstall and reinstalled but the same error occurs. This is happening for few days now and I'm not sure what to do to fix it. Can someone please help me?
Could not load driver appliand. This can happen if product has previously been uninstalled and then reinstalled again before rebooting the machine.
Read moreArista Transcoder doesn't work in openSUSE 12.1. It always throws an error. I tried to install plugins from the openSUSE repo but it also didn't work. The error stated that there is a missing elements and that's why I cannot add the conversion. How will I be able to resolve this?
Cannot add conversion to queue because of missing elements!
OK
Read moreI'm adding a picture to my wallpaper with Bodhi Linux. I tried to go to the settings and choose the wallpaper and then picture but the error still appears. It keeps on saying "Enlightenment was unable to import he picture due to conversion errors." I tried to modify the themes but it did not help. Everything is up-to-date. What should I do?
Hello Professionals,
The download and the installation of beta version went pretty well and good without any problem. But the problem triggered as soon I start the application, it then immediately closes the program. Is there any system requirement for this? I have windows 2012 operating system. Hunting for solution please help me. Your help isreally great. Thanks.
Application Error
Exception ElnvalidPointer in module BlurayConverterUltimate.exe at
00005BF5.
Invalid pointer operation.
OK
Read moreI have error on downloading Synaptic. I just updated my system this morning and updated 10 files. After that, the error appears instantly.
(as superuser)
APT system reports:
W: Some error occurred while running transaction
OK
I tried to stop the process of downloading updates but it doesn't help. Where is this error coming from? Please give me some insight. Thank you.
Read moreHi,
I have updated my Windows 8 to Windows 8.1 and I have this error when I want to open some programs. The first error is this with Paint.Net. I never experienced this error before and I don’t know what happened. Does anyone can help me to fix this ? Why I have this kind of errors? It might be because of the update? Thank you!
Error opening file for writing:
C:UsersMartinAppDataLocalTempPdnSetupSetupshim.exe
Click Abort to stop the installation,
Retry to try again, or
lgnore to skip this file.
Read moreWhen I run Synaptic, I received an error. Even if I try to add or remove it again, the same error incurs. There is no issue with the permission and I already tried what is suggested in the other site. I also run the command "sudo chown USERNAME .xauthority to no avail. I can still launch synaptic via the terminal. What seems to be the issue here? Any help?
Failed to run /urs/sbin/synaptic as user root.
Unable to copy the user's Xauthorization file.
Close
Read more
