Archive
Hi friends,
When I try to open a file in Windows Live Movie Maker, it throws me an error message. The error states me that the file may be corrupted. So I followed the common method of uninstall and reinstalling it again, but no luck. Do I need to run the antivirus? Do I need to run CCleaner? Which one helps me? Please help. Thanks.
One or more of the effects files that Movie Maker needs in order to run is corrupted. Please repair Movie Maker by clicking “Uninstall a program” in Control Panel, and the double-clicking...
Read more
Hi friends,
I am not a computer person; I have a problem with Microsoft excel 2000. The problem is when I try to import data from the web source in Excel, I get this error message. I tried this in function in different computers, getting this error in every computer. Am I going wrong anywhere? Is this a bug in Microsoft Excel? Please explain me. Thanks.
File cannot be opened because:
Invalid xml declaration.
Line 448, Position 3.
Read more
Hi trouble shooters,
When I am in the process of installing the Microsoft Lync 2010 in the computer I stuck up with the error message. My computer has windows operating system and it operates without any problem, the only problem right now is this following error message. Is the Lync 2010 is not compatible with windows 7 operating system? Any other option is available to install the Lync? Someone could help me to fix this error. Thanks.
This product requires at least Mircosoft Windows Server 2003 SP1 or Microsoft Windows XP SP3.
Read more
I tried to install the BlueStacks in the computer to connect my BlackBerry Phone. The download was complete, but the error appears while I setup. And I then tried to repair the software and install but I get the same error message again. How will I setup the Bluestacks? Do I need to change the settings or properties? Please help. Thanks.
Error 1706.No valid source could be found for product BlackBerry Desktop Software 7.1. The Windows Installer cannot continue.
Read more
Hey,
I am getting this error whenever I try to back up my iPod using sharepod in my computer. ITunes works perfectly fine as an individual. But the problem triggers when they are all connected together. Am I going wrong anywhere? I am not a technical person, so please help me out for this issue. Thanks in advance.
Warning: SharePod encountered an error while loading!
Please email [email protected], (giving the following error number and description) for help.
Error number: -2147221231
Error description: Automation error
ClassFactory cannot supply requested class
Read more
Hello whizzes,
I am new to Adobe Photoshop CS6, download and installation was good without any issues. I started working on the basics things on it, after a while I am getting this below error message. This makes me frustrated and makes me tired, how to solve this error? Thinking of whether Adobe is corrupted. So do I need to re-install it again? I am welcoming your suggestions. Thanks in advance.
C:Program FilesAdobeAdobe Photoshop CS6 (64 Bit)Photoshop.exe
Illegal operation attempted on a registry key that has been marked for deletion.
Read more
Hello friends,
When I try to setup the FL Studio 9 it failed with an error message. I tried again but at the same point I am getting this error message. I tried other options but in some way the installation was stopped. How do I install the FL Studio? I confirmed the compatibility and system requirement, it seems to be good. Help guys. Thanks in advance.
Error opening file for writing:
C:UsersDualCoreAppDataLocalTempOpenCandyOCSetupHlp.dll
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
Read more
Hello DBA’s,
When I am working in AutoPlant SS3, in project mode when a new drawing is created the database MDB file is not created. I got this database error message while I am trying to save the changes. How do I get a connection to the source database? I have a doubt whether this error might corrupt my database. Guide me fix the error. Thanks in advance.
ATDB0309: Failed to get a connection to the source database for document C:ProgramDataBentleyPlant V8iBentley Plant V8i ProjectsSAMPLE_IMPERIALPipingDrawings1.DWG
This will force the application to exit.
Read more
Hi all,
I have Microsoft security essentials antivirus to protect my system. I set to scan every week by default. By mistake I clicked the pop up advertisement while watching a video. I got little bit scared whether it might download some virus, so immediately I started to run the antivirus. But I got this error message, ‘system is connected to Wi-Fi’. Why I am getting this error? Please suggest me some solutions. Thanks.
Virus & spyware definitions update failed
Microsoft Security Essentials wasn’t able to check for virus & spyware definition updates.
Make sure your computer is connected...
Read more
Hi friends,
I love this game, when I recently updated the latest patch in my system I am getting this error message. Before the patch update everything worked well and good, the problem is after the patch update. This means the problem is with the patch, how do I fix? Could I able to remove the update? Please help me to play this game. Does anyone know how to fix the problem? Thanks.
The procedure entry point av_codec_set_pkt_timebase could not be located in the dynamic link library avcodec-54.dll.
Read more
