Archive
Today I did the required updates for iTunes and now it gives me this error. I don’t know why it cannot create a secure network now and with the previous version I never had an error. If I press OK nothing is happen and I have to open iTunes again and the error pops up again. Can anyone help me to fix this error?
Thank you!
iTunes could not connect to the iTunes Store. A secure network connection could not be established. Make sure SSL 3.0 or TLS 1.0 is enabled in the Internet Options...
Read more
Hello there,
Today I reinstalled my Windows 7 (x86) on my laptop and I have this problem installing iTunes. I have downloaded a few different versions from different servers but I can’t install it. It worked just fine before I reinstall the Windows. Can anyone help me to install iTunes? Please tell me the steps to install and if possible provide me a good installer.
Thank you!
There is a problem with this Windows installer package. A program required for this install to complete could not be run. Contact your support personnel or package vendor.
Read more
My iPhone is rebooting from 5 to 10 minutes so I put it on Recovery Mode when this error appeared. My warranty certificate expired and I cannot use and also I think that the cost of reparations is pretty high. Is there a way to fix this error? Can I repair my iPhone by myself?
Thank you experts!
The iPhone “iPhone” could not be restored. An unknown error occurred (13).
Read more
Hi experts,
After I connected my iPhone to my laptop this error message. I am not a Pro with PCs I don’t really know what it means and how this error can be solved. Does any can help me please to solve this error? What this error means and why I have this?
Thank you!
Apple Application Support was not found. Apple Application Support is required to run iTunesHelper. Please uninstall iTunes, then install iTunes again. Error 2.
Read more
Hello experts,
My PC can run videos with 1080p and also I can watch full HD movies. I have this error and the iTunes tell me that my PC cannot run such a high resolution. Does anyone had this kind of error before? How you solved this error guys?
Thanks!
This computer may not be able to play 1080p videos. You can still download these videos for use on other devices.
Read more
I have checked my Internet connections and everything is working just fine. The problem is iTunes because is not working due to network connection. This is my first version of iTunes and also the first time when I want to use to connect with my iPad Mini. Why the iTunes cannot connect to the Internet ?
My Internet connection is working just fine.
Thank you !
We could not complete your iTunes Store request. The network connection could not established.
Read more
This morning this error appeared and now I cannot connect to iTunes Store. Yesterday everything worked fine and now I cannot connect to the Store when I need it the most. Can anyone please help me to fix this iTunes error? Why is not working now?
Thanks!
iTunes could not connect to the iTunes Store. An unknown error occurred (-3212).
Read more
Hi there,
I have this sign in notepad, the one that is marked with red rectangle and I don’t know what it means and how it appeared. Since I have this sign everything I try to save, after I close the document and open it again is empty. Can anyone help me to fix this? What this sign is?
Thank you!
Read more
Hi there,
This error message box appeared on my phone while I was trying to update Audible for Android. The thing is that I cannot use the app until I make the necessary updates. Can any expert provide me a link from where I can make the updates ? Why I cannot update the app ?
Thank you !
Error
Update for “Audible for Android” could not be downloaded due an error. (Error retrieving information from server. [RPC:S-5:AEC-0])
Read more
During the mission of a game that I play on my iPad this error appeared and closed my game. Is the first error of this game that I had and I really want to finish this game. Can anyone help me to fix this error ? Please if is possible give me a solution that won’t require me to reinstall the game…
Thank you experts !
Error!
The game encountered an unexpected error and had to shut down.
I’m sorry for the inconvenience. Tap OK to send an error report to me. J
System.IO.FileNotFoundException: File not Found.
File name: ‘/Application/assets/images/logo.pnh’
At Sce.PlayStation.HighLevel.UI.AssetManage.LoadTexture...
Read more
