Archive
After I have rebooted my PC this morning because it was very slow, this error message appeared on my desktop. I didn’t make any changes before reboot. I would like to know if can anyone help me please to solve this error without reinstalling my Windows? What happened to my PC and what is causing this error?
Thanks!
External component has thrown an exception.
OK
Read moreHi there,
My HP printer software required an update. I have accepted to do the updates but instead of installation this error message popped-up. I ran again the update manager and the error appeared again instead of the install wizard. Can anyone help me please to update my HP software? Why it gives me such an error?
Thanks!
HP LoadRunner 9.52
Upgrade patch cannot be installed because the program to be upgraded
— may be missing, or the patch may update different version of the program.
Verify That “HP LoadRunner Software 9.51” exists on your machine.
OK
Read moreHello,
I have this error when I want to backup some files from my PC. I am not experienced making backups and also not to solve errors. I am a beginner with PCs. Can anyone recommend me some softwares for backup ? How can I solve this error? Please also tell me how can I make a correct backup?
Thanks!
Device <4> Erase failed! CONTROLLER FAILURE or HARDWARE ERROR
OK
Read moreHello,
I have this error at my office. The printer is not working anymore and I am the only one with the problem. The IT section told me that they will help me in 3 days. I can’t wait for 3 days because I really need to use the printer. My friend recommended me this website and told me that I will get a response no late than 12 hours. Please help me to fix this Techyv!
Thank you very much!
Unable to verify the printer on your network.
Unable to connect to 192.168.1.1 due to an...
Read moreHi there,
Recently I experienced some DLL error caused by the missing file. I did not delete any files and I ran a DLL fixer and still I have some DLL files missing. Does anyone can help me to fix this error? Why the DLL fixer didn’t work?
Thank you!
SiIkCentraI Message
Failed to execute DDL statement (C:Program FilesBorlandSC Test Manager 2008 R2ConfAppServerDbUpgradeTM_4001.MSSQL.ddl - Line 6): Cannot insert the value NULL into column ChangedAt, table ITDSEGUETM.dbo.TM_Attributes’S column does not allow nulls INSERT fails,
Read more
Hi there,
I have a new Linux for two days and today for the first time this error appeared on my desktop after the startup finished to load. Is my first Linux and I am lost with this error. Please experts help me to fix this!
Why I have this error and is a system error or a user error?
Thanks!
Unable to mount Marcos Lai
Error mounting mount exited with exit code 1: helper failed mount: wrong fs type. bad option, bad superbiock on /dev/sdb1, missing codepage or helper program, or other error In some cases useful...
Read moreHi there,
I have this error on Rockstar Games Social Club. Sometimes is working just fine but there are some days when I cannot open it at all because of this error. Can anyone help me please to solve this error ? What is best solution that can help me to fix this without reinstalling the game and all ?
Thank you !
The application has encountered a fatal error and must close.
Please restart the application or contact support at:
https://support.rockstargames.com/
OK
Read moreHi,
This morning this error message showed up on my desktop when I wanted to print 2 files. Also I have errors when I want to open the printer applications. Is for the 1st time when I have this kind of errors and I don’t know why it happens when I need the most my printer to work. Please help me to fix this error. How can I prevent this to happen again?
Thank you!
15:23:59,761 ERROR [BaseAuthenticator: 150:http--O.O.0.0-71 16-1] Ticket is null!
15:23:59, 828 ERROR [DpAuthenticateResource: 136:http--0.0.0.0-71 16-1] forbidden.
15:23:59, 834 ERROR [BaseAuthenticator: 150:http--0.0.0.0-71 16-1] Ticket is...
Read moreHi there,
While extracting an archive this error with not enough memory appeared. I have checked my HDD partition and I have enough available space and still. I tried many times to extract and every time the same error appeared. Can anyone provide me a solution for this error ? What memory is not enough to extract this archive ?
Thanks !
Extracting archive Data1.bin…(10.5%)
ISDone.dll
An error occurred while unpacking: Not enough memory!
Unarc.dll returned an error code:-5
ERROR: archive data corrupted (decompression fails)
OK
Read moreHi,
I have installed iTunes twice and thought that this error message box won’t appear but is not working. On the official site it says that is compatible with Windows 7 and I don’t understand why is not working. I have installed it normal following the steps in the manual. How can I make it to work properly? Why I have this problem? I will have this problem with other softwares in the future?
Thank you!
iTunes .exe has been set to run in compatibility mode for an older version of Windows. For best result turn...
Read more
