Archive
My HP printer laser jet had an error this morning and I tried to repair it. I searched in the setting and I found this Recovery Manager. The problem is that is giving me errors. Does anyone have any idea about what is happening with my printer? Why my HP printer is full of errors?
Thank you!
Cannot load assembly:
System.Data.SQlite. Version=1.0.61.0, Culture=neutral.
PublicKeyToken=db37bc2d44ft139
The application will now exit.
Read more
Hello experts,
This error message box pops-up suddenly and randomly on my desktop. Sometimes can be very annoying and I want to get rid of it as soon as possible. Can anyone of you guys help me to fix this?
Why I have this error with iTunes?
Thanks!
System extension cannot be used
The system extension “/system/library/Extensions/CNQL212_ClassicNoteSize.kext” was installed improperly and cannot be used. Please try re-installing it, or contact the products vendor for an update.
Read more
Hi experts,
When I want to configure a new client with Microsoft Outlook this unexpected error appears and I have to make the settings again. The result is this unexpected error, again and again. Is working just fine with my other 2 account to connect and sending e-mails, but I cannot create and configure another one. Anyone knows why? What might be the problem and how can I solve it please?
Thank you!
Microsoft Dynamics CRM -- Webpage Dialog
Unexpected Error
An error has occurred.
Try this action again. If the problem continues, check the Microsoft Dynamics CRM
Community for...
Read more
This No root file system message appeared during the update of Ubuntu 11.04. I tried to make different partitions with different sizes and still I couldn’t get rid of this error. Is there any expert online that can help me please to solve this ? What is the problem ?
Thank you !
Allocate drive space
No root file system
No root file system is defined.
Please correct this form the partitioning menu.
OK
Read more
I have this error every time I try to connect my electronic piano to my PC. The thing is that my Windows is up to date, all softwares are updated, and drivers also are updated, including this one. Please guys help me to connect this and tell me why I have this error? What is the main cause of this error?
Thank you!
KeyStudio 49i Not Found
It appears that the KeyStudio 49i is not connected to your computer. Please connect the KeyStudlo 49i, and the re-launch the M-Audio GM Module. if the KeyStudio 491 is...
Read more
Hello experts,
I have this error at my school. The printer is not working anymore and I am the only one with the problem. The IT teacher told me that I have to solve this as a test. My friend recommended me this website and told me that I will get a response no late than 12 hours. Please help me to fix this Techyv!
Thanks!
HP Installer
Unsupported Network
Your Mac is connected to 802.lx secured infrastructure network. Please contact your network administrator to setup the device or click Continue” to choose another network.
Cancel Continue
Read more
This is the error I have every time I want to install an Intelligent Platform to my PC with Windows Server 2008 (x86). I don’t know why I have this error since I already have installed Windows Server 2008. I can’t understand and I don’t know how this error can be fixed. Does anyone have any idea on how I can solve this one? Why I can’t install IPMI since I meet all the requirements?
Thank you!
The IPMI driver only supports Windows Server 2000, 2003 and 2008
OK
Read more
Hi there,
I have this error every time I try to sync my phone with my laptop. Below is the error message. Is my first smartphone and I don’t have big experience with this kind of devices? Can anyone please help me to fix this error? Is there any other way to sync the device with a laptop?
Thank you!
No devices are connected. Connect a device then relaunch WebOS Quick Install.
Read more
Hello experts,
I did some changes to my server and I wasn’t pleased about the result. It was with error and crashes. I tried to recover and repair what I broke and during the recovery this failure message appeared in the end. Can someone help me to run a full recovery without any failure? If this possible please give some tips about servers.
Thanks!
Server recovery complete
Failure
The Server recovery operation failed because the primary volume on the Server could not be written. Click Help for information about fixing the problem. Click Finish to reboot your Server.
Help
Read more
I have a laptop with Windows 7. It's about two weeks old since the last install of Windows, and I have this error when I want to run the install. Can anyone help me fixing this error? Is the original CD driver so why it has errors?
Thanks!
HP Support Assistant - InstallShield Wizard
C:UsersBurtAppDataLocalTempSetupAC.exe/i
C:UsersBurtAppDataLocalTemp /v “/qn /1+ setuplogac.bct
ApplicationName= “Mobile”
FilesPath= “C:UsersBurtAppDataLocalTempACO”
ARPSYSTEMCOMPONENT=1”
OK
Read more
