Archive
Hi experts,
I have installed on my PC the game Sam2 and when I tried to open it this long error appeared and requests some core.dll file. I don’t know how to solve this so I need an expert to help me with. Is anyone available and can help me to solve it ?
Thank you !
Sam2.exe – Entry Point Not Found
The procedure entry point ?LoadModule@CModuleLoader@SeriousEngine@@QAEXPBDH@Z could not be located in the dynamic link library core.dll.
OK
Read more
Hi experts,
This Error appears when I want to install Oracle on my PC. I have downloaded the installer from the official Oracle website and is not working. If the installer from the official website is not working I don’t think that another installer will work. Can you provide me a good installer of Oracle. Why this one is not working? Thanks!
Oracle Universal Installer: Install
Error
Error in invoking target install of makefile/u01/app/oracle/product/9.2.0/ctx/lib/ins_ctx.mk
Press ‘Help’ for more information.
Press ‘Retry’ to try again.
Press ‘Ignore’ to ignore this error and go on.
Press ‘Cancel’ to stop this installation
Help Retry Ignore
Read more
Hello there,
This message appears when I try to install this plug-in. I have installed everything that was required and now with this I don’t know what to do next. Does anyone have any solution for this plug-in ? What should I install so that HomeSeer plug-in to work ?
Thanks !
HomeSeer Plug-in DeviceLoggerContinuous
HomeSeer does not appear to be installed on this system, the install cannot continue.
OK
Read more
Hi there,
I want to update the firmware of my ZTE MF60, and when I click Apply Patch nothing happens. I am stuck with this idea of updating firmware and I cannot do it. Can anyone help me to update this firmware ? Why nothing happens when I click Apply Patch ?
Thank you !
MF60 Firmware installer patch
This program applies a MEMORY ONLY patch to the MF60 firmware installer to skip the version check routine, and optionally install the firmware to be network unlocked.
Read my ZTE MF60 Firmware/unlock Guide
It is designed for firmware installer DL MF60 BP...
Read more
This error appeared during the update of World of Tanks. I made the update many time but this requested one fails and the application cannot continue. I have downloaded the updates manually and still this error appears. Can anyone help me to update my game please ?
Thanks !
Critical error.
Failed to install updates.
The application cannot continue.
For details, see log file.
OK
Read more
Hello there,
I want to install the latest version of MapInfo Professional and this message appears. I don’t know what the Print Service means and why is not running on my laptop. Please is there anyone free who can help solving this problem ? How can I make The Print Service to run on my laptop ?
Thank you !
MapInfo Professional 10.0.1 Maintenance Release – InstallShield Wizard
The Print Service is not running on your computer. In order to upgrade the MapInfo PDF Printer, start the Print Spooler service and then restart the installer.
OK
Read more
Hi experts,
Blizzard gives me this error when I want to patch the game. I did as the error said and I reinstalled the game. The patch is not working, so the reinstallation of the game is not helping. Do you experts have a solution for this please? What could be the problem and how can I prevent it in the future? Thanks!
Blizzard PrePatch v2.70
An error has occurred preparing the patch. This problem can commonly be corrected by reinstalling the game and trying the update again. If this error repeats then contact Blizzard Technical Support.
Please press...
Read more
Hi there,
I got this message while scanning the system for necessary updates and nothing was installed but it says that my device has been modified. The problem is that some apps request my permission to install some updates even if says that none are available. Does anyone have any idea about this ? What should I do ?
Thank you !
About device
Software update
Your device has been modified.
Software updates are not available.
OK
Read more
This morning this message from Kaspersky appeared and is about uTorrent. The problem is that I don’t have installed uTorrent on my PC. I have checked in Program Files if is installed and I didn’t find the folder in there. I am confused and someone can help me to fix this ? Where I can find uTorrent ?
Thanks !
Kaspersky Anti-Virus
The application C:Program FilesuTorrentuTorrent.exe cannot establish connection with server 66.90.104.142. Please check your internet connection settings. If you have a firewall installed, check that application avp.exe is allowed internet access.
Read more
After I “cleaned” my BlackBerry using BBSAK this error appeared and tells me that No OS found. I am scared because I might delete everything from my phone, even OS. Please help me !!! Can anyone have a solution for this ? What should I do ?
Thank you experts !
BBSAK
No OS found. Please install a OS for your phone.
OK
Read more
