Archive
Speech recognition shows me this message every time I open the app. If I tap Close the app is closing and nothing happens next. It worked just fine until now and I don’t know what could be the problem. Can anyone help me to fix this ? What this means ?
Thank you !
Speech recognition over network is disabled You can change this in Speech settings.
Close
Read moreHi there,
I try to copy some pics from my camera to my MAC and this Warning message appears and doesn’t let me to copy them. If I click OK nothing happens and if I try again the same message appears. Does anyone have any idea why I cannot copy the pics on my MAC ?
Thanks !
Warning
“source” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.
OK
Read moreHi experts,
During the install of a new patch for my game Rift this error message appeared. The patch is an official one and I was expected to work just fine. The only good option is to click Abort and everything is closing. Can anyone tell me what is the problem with this ? Is a problem with my Windows ? The patch is working just fine on my friends PCs.
Thank you !
Rift Patch live – 28-9a (main@378937) Setup
Error opening file for writing:
C:Program Files (x86)RIFT Gameselfpatchlive.exe
Click Abort to stop the installation,
Retry to try again, or
Ignore to...
Read moreHello,
I get this Write Error when I want to burn some files and it doesn’t matter what I want to burn the message is the same-the media is protected. Can anyone help me to fix this error please ? Is this error caused by me PC ?
Thanks !
Write Error
An error occurred when attempting to write data to handle.
Error 19: The media is write protected.
OK
Read moreHello,
VBosxTestOGL.exe stopped to work while trying to open VirtualBox. I don’t know what this error about memory and is the first error of this kind. Can anyone help me please to solve this error ? What is causing this ?
Thanks !
VBosxTestOGL.exe – Application Error
The instruction at 0x806b58e2 referenced memory at 0x0000000. The memory could not be read.
Click on OK to terminate the program.
OK
Read moreHello there,
Sometime I have this error when I listen music, when I watch movies and even when I play some games. Every time this closes my programs and I have to open them again and is working. I want to get rid of this error because starts to be very annoying. Can anyone help me fix this ? What caused this error ?
Thanks !
Error
Setup is unable to detect a supported product on your system. Please ensure that your product is properly installed before running this Setup program.
Setup will exit.
OK
When I want to install Confluence Evaluation during the installation this error message appears and I can’t continue the install. Is an official installer and it have some error as I see. Is there a way to install this program properly ?
Thank you !
Confluence Evaluation 3.3.1 Setup
C:Program Files (x86)AtlassianConfluence Evaluation 3.3.1confluence.exe
Ignore to skip this file.
Abort
Retry
Ignore
Read moreHello,
Today I install Android Studio on my laptop and when I tried to open it this error stopped my action. I followed the instruction in the error I nothing was found. I downloaded and reinstalled the Android Studio and same error appeared. Please is anyone available to help me with this error ? I did something wrong when I installed Android Studio ?
Thank you !
Starting Android Emulator
Starting emulator for AVD “GPUAccelerated’
Emulator: ERROR: Could not load OpenGLES emulation library: Could not load DLL!
Emulator: WARNING: Could not initialize OpengIES
Emulation, using software renderer.
Read moreHi,
My app WhatsApp gives me this error every time I want to open it. I heard that the WhatsApp are experiencing some issues but it seems like I am the only one with this error. The app is working just fine on my friend devices. Can anyone tell me what is happening with my phone and my app? Thank you!
We’re having trouble installing this app.
Tap and hold the item, then tap Retry.
If you’re trying to update an existing app, and the problem continues, you might need to uninstall the app then install it again.
Retry close
Read moreHi there,
After the TERA finished the installation I got this error when I tried to open it. The installation was OK without any errors so I don’t know what could cause this error. Can anyone help me please to fix this error ? What is causing this ? How can I prevent this in the future ?
Thanks !
TERA Launcher
The TERA Launcher is unable to load the CopyCub.dll file.
If this problem persists please visit tera-support.enmasse.com for more additional help
OK
Read more
